LED matrix control using arrays and state machine?
Hello,
I've been working on a custom tail lamp project and have made some decent progress. I have a working (but certainly sloppy) sketch that looks at 4 input pins to determine an output array or a sequence of arrays (progressive turn signals with 6+ frames etc)
The last thing I'm trying to learn for this project, is how to make it instantly update for a change in the input pins. Obviously this doesn't work with the way I have it written using delays, etc
I've looked at a few projects using blink without delay and variations but haven't been able to wrap my head around how to implement it here.
This change is important for the project - I can't have a delay when in the middle of a turn signal animation before the brake lamps come on, etc.
Please see my messy (yet somehow works) sketch:
Thank you for any help. I'm sure this is basic stuff - I have a lot to learn but having fun so far!
//tail lamp dev v3
#define PIN 3
const int sensorPin1 = A0;    // select a input pin for control 1 RUN LAMP
const int sensorPin2 = A1;    // select a input pin for control 2 TURN SIGNAL
const int sensorPin3 = A2;    // select a input pin for control 3 BRAKE LIGHT
const int sensorPin4 = A3;    // select a input pin for control 4 REVERSE
int sensorValue1 = A0;  // variable to store the value coming from the sensor
int sensorValue2 = A1;  // variable to store the value coming from the sensor
int sensorValue3 = A2;  // variable to store the value coming from the sensor
int sensorValue4 = A3;  // variable to store the value coming from the sensor
//off array
                       const uint32_t ledarrayoff[] = {
                       0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
//run
                       const uint32_t ledarrayrun[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000,
//brake
                      const uint32_t ledarraybrake[] = {
                      0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
//reverse
                       const uint32_t ledarrayreverse[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
// run reverse
                       const uint32_t ledarrayrunreverse[] = {0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
// brake reverse
                       const uint32_t ledarraybrakereverse[] = {0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
//turn anime
                       const uint32_t ledarrayt0[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayt1[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt2[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt3[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt4[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayt5[] = {
                       0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
//turn brake anime
                       const uint32_t ledarraytb1[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb2[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb3[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb4[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb5[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
//turn reverse anime
                       const uint32_t ledarrayrt1[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt2[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt3[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt4[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt5[] = {
const int NUM_PIXELS = 256;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_PIXELS, PIN, NEO_GRB);
//unsigned long startMillis;  //some global variables available anywhere in the program
//unsigned long currentMillis;
//const unsigned long period = 1000;  //the value is a number of milliseconds
  strip.begin();
  strip.setBrightness(255);
  strip.show();   // Initialize all pixels to 'off'
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
  pinMode(A3, OUTPUT);
  //startMillis = millis();  //initial start time
int state1 = 0; // initialize state1 value to zero
int state2 = 0; // initialize state2 value to zero
int state3 = 0; // initialize state3 value to zero
int state4 = 0; // initialize state4 value to zero
if(digitalRead(sensorPin1)== HIGH) // read the value from the sensor1:
state1 = 1;
else state1 = 0;
delay(10);
if(digitalRead(sensorPin2)== HIGH) // read the value from the sensor2:
state2 = 2;
else state2 = 0;
delay(10);
if(digitalRead(sensorPin3)== HIGH) // read the value from the sensor3:
state3 = 4;
else state3 = 0;
delay(10);
if(digitalRead(sensorPin4)== HIGH) // read the value from the sensor4:
state4 = 8;
else state4 = 0;
delay(10);
//totals of state for which frame to render
if(state1 + state2 + state3 + state4 == 0) //off
RenderFrame (ledarrayoff),
delay(10);
if(state1 + state2 + state3 + state4 == 1) //run
RenderFrame (ledarrayt0),
delay(10);
if(state1 + state2 + state3 + state4 == 2) //turn
delay(60),
RenderFrame (ledarrayt1),
delay(60),
RenderFrame (ledarrayt2),
delay(60),
RenderFrame (ledarrayt3),
delay(60),
RenderFrame (ledarrayt4),
delay(60),
RenderFrame (ledarrayt5),
delay(60),
delay(60);
if(state1 + state2 + state3 + state4 == 3) //run turn
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
if(state1 + state2 + state3 + state4 == 4) //brake
RenderFrame (ledarraybrake),
delay(50);
if(state1 + state2 + state3 + state4 == 5) //run brake
delay(50);
if(state1 + state2 + state3 + state4 == 6) //turn brake
delay(60),
RenderFrame (ledarraytb1),
delay(60),
RenderFrame (ledarraytb2),
delay(60),
RenderFrame (ledarraytb3),
delay(60),
RenderFrame (ledarraytb4),
delay(60),
RenderFrame (ledarraytb5),
delay(60);
if(state1 + state2 + state3 + state4 == 7) // run turn reverse
RenderFrame (ledarrayrunreverse),
delay(60),
RenderFrame (ledarrayrt1),
delay(60),
RenderFrame (ledarrayrt2),
delay(60),
RenderFrame (ledarrayrt3),
delay(60),
RenderFrame (ledarrayrt4),
delay(60),
RenderFrame (ledarrayrt5),
delay(60);
if(state1 + state2 + state3 + state4 == 8) // reverse
RenderFrame (ledarrayreverse),
delay(50);
if(state1 + state2 + state3 + state4 == 9) // run reverese
delay(50);
if(state1 + state2 + state3 + state4 == 10) // turn reverse
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
if(state1 + state2 + state3 + state4 == 11) //run turn reverse
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
if(state1 + state2 + state3 + state4 == 12) // brake reverse
RenderFrame (ledarraybrakereverse),
delay(40);
if(state1 + state2 + state3 + state4 == 13) // run brake reverse
delay(40);
if(state1 + state2 + state3 + state4 == 15) // run turn brake reverse
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
void RenderFrame(const uint32_t *arr)
  for (uint16_t t = 0; t < 256; t++)
   strip.setPixelColor(t, arr[t]);
  strip.show();
You should put all those array declarations in a header file.
Don't copy text like You did. It's not readable. Read Your post and experience what it looks like. The text is not adjusted to the width of the window.
That's a great idea!
Is there a good tutorial on how to do that? I'm looking into that now.
I assume that would be using the #include function?
In the text of the post or the sketch?
I'm sorry about that - new to the forum and arduino
The beginning text...
Correct. Name the file with a '.h' extension, like "ledarray.h", put it in the same folder as the sketch, restart the GUI and it will appear as another tab in the IDE.
Does the code you posted even work? I tried to run it, this didn't look right:
and a few other odd things. But now that I've fixed it up a bit, it is consuming too much memory and compiklation fails.
What Arduino board are you using? Can you confirm the code you posted should do something? Or post some code that does in fact work.
TIA
a7
Thanks Alto777
Using Nano 33 loT
It does, somehow
The pinMode stuff came from some example. I don't think it works without it... I'm sure I'm doing something wrong there. It should probably be INPUT?
The goal is to read the pins (high or low) and set a state value to each reading of the pin.
Then the state values are added to get a total state of what pins are on and off. From there I assigned an array or set of arrays to display based on the total value of the 4 pins. I'm sure there is an easier, elegant way to do such at thing, but my beginner brain hasn't figured it out yet!
Sketch with the arrays moved to header file
//tail lamp dev v3
#include  "taillightarrays.h"
#define PIN 3
const int sensorPin1 = A0;    // select a input pin for control 1 RUN LAMP
const int sensorPin2 = A1;    // select a input pin for control 2 TURN SIGNAL
const int sensorPin3 = A2;    // select a input pin for control 3 BRAKE LIGHT
const int sensorPin4 = A3;    // select a input pin for control 4 REVERSE
int sensorValue1 = A0;  // variable to store the value coming from the sensor
int sensorValue2 = A1;  // variable to store the value coming from the sensor
int sensorValue3 = A2;  // variable to store the value coming from the sensor
int sensorValue4 = A3;  // variable to store the value coming from the sensor
  strip.begin();
state1 = 1;
else state1 = 0;
delay(10);
state2 = 2;
else state2 = 0;
delay(10);
state3 = 4;
else state3 = 0;
delay(10);
state4 = 8;
else state4 = 0;
delay(10);
delay(10);
delay(10);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(50);
delay(50);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(50);
delay(50);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
delay(40);
delay(40);
delay(60),
delay(60),
delay(60),
delay(60),
delay(60),
delay(60);
  strip.show();
It’s probably obvious, but could you just post this file like you did the code? TIA
The pins to be inputs should be inputs
pinMode(sensorPin2, INPUT);
if your logic is coming from other circuitry; I used pushbuttons and had
pinMode(sensorPin2, INPUT_PULLUP);
which means I go looking for LOW to mean presst rather than HIGH.
Where do your 4 input signals come from? I realize this is not your problem, that we can get to. :expressionless:
a7
Hi Alto,
I'll try it with the pins set as inputs.
The inputs pins (A0-A3) are switched to 5v. This will come from a small 12v to 5v converter on the car, but for now I'm just manually switching them to a 5v supply to set the input state to HIGH
I didn't actually realize I could just pull them to ground with the input pullup on. Maybe I'll use 4 micro relays per tail light to pull to ground instead. Sounds safer for the board :slight_smile:
Array .h (untested)
//off array
                       const uint32_t ledarrayoff[] = {
//run
                       const uint32_t ledarrayrun[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000,
//brake
                      const uint32_t ledarraybrake[] = {
                      0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
//reverse
                       const uint32_t ledarrayreverse[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
// run reverse
                       const uint32_t ledarrayrunreverse[] = {0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
// brake reverse
                       const uint32_t ledarraybrakereverse[] = {0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,
//turn anime
                       const uint32_t ledarrayt0[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayt1[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt2[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt3[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,
                       const uint32_t ledarrayt4[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayt5[] = {
                       0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
//turn brake anime
                       const uint32_t ledarraytb1[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb2[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb3[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb4[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
                       const uint32_t ledarraytb5[] = {
                       0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000,   //  1
//turn reverse anime
                       const uint32_t ledarrayrt1[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt2[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt3[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt4[] = {
                       0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FF0000, 0x00FF0000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00FFFFFF, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000, 0x00000000,   //  1
                       const uint32_t ledarrayrt5[] = {
You are using 3.3v board, is it still working? Maybe not for long
WOW, how did I not see that before :open_mouth:
IDK why I though it was 5v. Thankfully my supply is very limited and also puts out around 4.4v really.
I'll be switching to ground switched for sure
OK, I have nothing that this will run on. I get errors clearly related to memory on anything I use.
And here's another odd thing, again not the problem you write about, but just a strange way of doing things, had to look twice and convince myself it would work. This
  if (state1 + state2 + state3 + state4 == 2) //turn
    RenderFrame (ledarrayt0),
                delay(60),
                RenderFrame (ledarrayt1),
                delay(60),
                RenderFrame (ledarrayt2),
                delay(60),
                RenderFrame (ledarrayt3),
                delay(60),
                RenderFrame (ledarrayt4),
                delay(60),
                RenderFrame (ledarrayt5),
                delay(60),
                RenderFrame (ledarrayoff),
                delay(60);
would more commonly be written like
    if (state1 + state2 + state3 + state4 == 2)  {  //turn
        RenderFrame (ledarrayt0);
        delay(60);
        RenderFrame (ledarrayt1);
        delay(60);
        delay(60);
        delay(60);
        delay(60);
        delay(60);
        RenderFrame (ledarrayoff);
        delay(60);
By more common I mean to say I have never seen it done the way you did. It works fine, and I do not argue with success. But it would be more readable traditionally expressed.
Also not picking on you, but variables are practically free, so you could compute an animation number like
int totalState = state1 + state2 + state3 + state4;
and use it in all the if statements.
if (totalState == 8)...
Now for the real problem:
Each effect is some number of steps separated by delays. As you have found, this blinds your program to any changes in the inputs.
Since each effect is already cut into steps, the way to maintain an ability to change things is to use a finite state machine or FSM to do the animation.
Each call to the "machine" will advance the effect one frame. By calling the machine function periodically (informed by the desired time between frames) you can also keep an eye on the inputs.
Often in a FSM the next step is handled by a switch/case statement. Here you have relatively simple step in sequence from beginning to end.
Google
FSM Arduino traffic lights
and poke around a bit. It is quite a different approach, so expect a learn curve, but it is a very useful trick for your bag. Of tricks. FSMs are used alla time for just this kind of thing.
I googled and found this
https://create.arduino.cc/projecthub/48770/crossroad-traffic-lights-fsm-2f15d9
which I believe would be worth any time you spent there.
a7
Looks like I know what I'm attempting to understand tonight :slight_smile:
Thanks Alto!
When I do this, the RenderFrame gets an error not declared in this scope
I think i need to move the void RenderFrame(const uint32_t *arr) around?
C’est impossible!
More likely you’ve omitted a brace or used an extra one somewhere.
See if “auto format”, available in the IDE on some menu, lets you see where you’ve mismatched your braces.
Each if statement looks like
if (condition) {
      statement;
      statement;
      statement;
or just leave it the way you had, haha, it did work before all. :wink:
I just saw this reference in another thread, maybe also of interest to you:
a7
Control-T
By the way, I see no state machine in your code. Just assigning some inputs to variables called "state" something, doesn't count.
