Hello everyone, thank you for you time to. I have some issue with my LEDs output I use 74154 to leds matrix y-axis and 74138 to leds matrix x-axis and 7404 inversor. I connect the leds with IDE cable which 5-horizontal and 5-vertical. My master arduino successful make connection with my slave.But I send ax01y01(I use this char to indicate row and column) to my slave but it read ax01y0. Missing the char 3. Futhermore the LEDs is not light. I hope someone can help me. Your help will be helpful to me. I attach my master, slave coding and my diargram
Master code:
// Master Code
#include <Wire.h>
byte nChar =0;
char input[7];
void setup () {
Wire.begin();
if (nChar < 7) {if (Serial.available()) { input[nChar++] = Serial.read();}}
else {
Wire.beginTransmission(1);
//a
Wire.write(input[0]);
Serial.print("Drawer : ");
Serial.println(input[0]);
//x
Wire.write(input[1]);
Serial.print("Output : ");
Serial.println(input[1]);
//00
Wire.write(input[2]);
Wire.write(input[3]);
Serial.print(input[2]);
Serial.println(input[3]);
//y
Wire.write(input[4]);
Serial.println(input[4]);
//00
Wire.write(input[5]);
Wire.write(input[6]);
Serial.print(input[5]);
Serial.println(input[6]);
delay(15);
while (Serial.available())
//Remove extra
Serial.read();
Wire.endTransmission();
nChar = 0;
Slave Code:
#include <Wire.h>
int ledPins[] = {7, 6, 5, 4, 3, 2,};
int ledPins2[] = {7, 6, 5, 4, 3, 2};
byte count;
byte nChar;
char c;
char input[8];
char data[50] = "";
int n;
#define nBits sizeof(ledPins)/sizeof(ledPins[0])
#define nBits sizeof(ledPins2)/sizeof(ledPins[0])
Wire.begin(1);
Wire.onReceive(receiveEvent);
for (byte i = 0; i < nBits; i++) {
pinMode(ledPins[i], OUTPUT);
pinMode(ledPins2[i], OUTPUT);
if (nChar < 8) { //accumulate three characters
c = Serial.read();
input[nChar++] = c;
else {
input[8] = 0; //atoi() expects string terminator
n = atoi(input); //convert the input characters to integer
dispBinary(n);
delay(100); //wait for any additional characters
while (Serial.available()) { //ignore them
c = Serial.read();
nChar = 0;
void receiveEvent(int howMany)
while (1 < Wire.available()) {
char c = Wire.read();
Serial.print(c);
void dispBinary(int n) //Vertical
if (n >= 0 && n <= 6) {
digitalWrite (ledPins[i], n & 1);
n /= 2;
void dispBinary2(int n) //Horizontal
digitalWrite (ledPins2[i], n & 1);
n /= 2;
void b()
if (data[0] != 'a')
dispBinary(atoi("00"));
delay(100);
dispBinary2(atoi("00"));
delay(100);
goto fin;
if (data[1] = 'x')
char xdata[2] = {data[2], data[3]};//(data[2], data[3]);
dispBinary2(atoi(xdata));
delay(100);
if (data[4] = 'y')
char ydata[2] = {data[5], data[6]};//(data[5], data[6]);
dispBinary(atoi(ydata));
delay(100);
fin:;
