LED Matrix MX72 19 : how to display 2 digits
Hello,
As i am just a beginner with arduino, i try to figure out a few problems with LED matrix 7219 4 in 1.
I just post a clue to help other beginners https://forum.arduino.cc/index.php?topic=560635.0
But now, i am facing a bigger problem and i would appreciate a bit of help.
I am just trying to put a 2 digit number on this led matrix
I must admit that i am a bit lost
Here is my code:
#include <MD_MAX72xx.h>
#include <SPI.h>
// Turn on debug statements to the serial output
#define  DEBUG  1
#if  DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTD(x) Serial.println(x, DEC)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTD(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES  4
#define CLK_PIN   13  // or SCK
#define DATA_PIN  11  // or MOSI
#define CS_PIN    10  // or SS
// SPI hardware interface
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// We always wait a bit between updates of the display
#define  DELAYTIME  100  // in milliseconds
//____________ should be displayed ; A goes from 0 to 30
int NumA;
void showNum(void)
  mx.clear();
  mx.update(MD_MAX72XX::OFF);
 for ( NumA=0; NumA<30; NumA++)
 //NumA
    mx.clear(0);
    mx.setChar(COL_SIZE-2, NumA);
    mx.update();
    delay(DELAYTIME*2);
  mx.update(MD_MAX72XX::ON);
    mx.begin();
#if  DEBUG
  Serial.begin(57600);
#endif
#if 1
    mx.clear();
  showNum();
  #endif
And it gives me in hexadecimal but not as figures…
Thanks a lot in advance
damien
The ASCII character for with codes 0 to 9 is not the same as the ASCII character '0' to '9'.
To get '0' to '9', add the code '0' to the number:
char c = i + '0';
Once you get to 2 characters (number > 9) you will need to treat them separately.
So many thanks for your reply
For the moment, i did not succeed to make it work
but i will try to understand what you told me
