I’m making my first real project with my custom shield I made, see it in exhibition.
I’m making a 16 step musical sequencer that has a combination of 4 drum noises and 4 notes.
So far, I’m just working on making it play the audio (no interactivity yet), which it does fine, but the display does not function correctly.
I tried to program it in a way that the arrays for the beat and for the music directly affect the display, and it works well, except for one little thing. The fifth row from the top, the one for the note C4, does not display.
It should show a scanning red line, the playhead, and it should also show a green dot representing a note.
The top four lines are the drum tracks, the bottom four are the tones.
I’ve been puzzled for a while now, and I have no clue!
Here is the code, with only the parts related to the display: (I’ve ensured that the problem still remains, and that the row is functional.):
#include <Tone.h>
const int clockPin = 2;
const int dataPin = 3;
const int latch1 = 4;
const int latch2 = 5;
#define PAUSE 0
#define BASS 1
#define SNARE 2
#define HHATC 3
#define HHATO 4
int beat[16] = {
BASS, HHATC, HHATC, HHATC,
SNARE, PAUSE, BASS, HHATC,
HHATC, HHATC, BASS, PAUSE,
SNARE, BASS, HHATO, PAUSE
#define REST 99
int music[16] = {
NOTE_C3, NOTE_C3, NOTE_C3, NOTE_C3,
NOTE_C4, REST, NOTE_DS3, NOTE_DS3,
NOTE_DS3, NOTE_C3, NOTE_G3, REST,
NOTE_C4, NOTE_C4, NOTE_C4, REST
int row=0;
byte redCol1;
byte greenCol1;
byte redCol2;
byte greenCol2;
int tempo = 125;
int position;
randomSeed(analogRead(0));
position = 0;
for(int i = 2; i<=5; i++) {
pinMode(i, OUTPUT);
unsigned long time = millis();
while(millis() - time <= tempo) {
allStep(position, time);
if(position < 15) {
position++;
else {
position = 0;
void allStep(int position, unsigned long startTime) {
//silencer(position);
//snareStep(position, startTime);
//bassStep(position);
//hhcStep(position, startTime);
//hhoStep(position, startTime);
//leadStep(position);
displayStep(position);
//etc...
void displayStep(int position) {
//row byte generator
row++;
if(row==8) {
row=0;
byte rowByte = 1 << row;
//red byte generator
if(position <= 7) {
redCol1 = B10000000 >> position;
redCol2 = B00000000;
else if(position >= 8) {
redCol2 = B10000000 >> (position - 8);
redCol1 = B00000000;
//green byte generator
byte rowNote=0;
switch(row) {
case 7:
rowNote = NOTE_C3;
case 6:
rowNote = NOTE_DS3;
case 5:
rowNote = NOTE_G3;
case 4:
rowNote = NOTE_C4;
//matrix1
greenCol1 = 0;
for(int i = 0; i <=7; i++) {
if(row+1 == beat[i]) {
greenCol1 = greenCol1 | B10000000 >> i;
if(rowNote == music[i]) {
//matrix2
greenCol2 = 0;
if(row+1 == beat[i+8]) {
greenCol2 = greenCol2 | B10000000 >> i;
if(rowNote == music[i+8]) {
digitalWrite(latch1, LOW);
shiftSwap(rowByte, MSBFIRST);
shiftSwap(greenCol1, LSBFIRST);
shiftSwap(redCol1, LSBFIRST);
digitalWrite(latch1, HIGH);
digitalWrite(latch2, LOW);
shiftSwap(greenCol2, LSBFIRST);
shiftSwap(redCol2, LSBFIRST);
digitalWrite(latch2, HIGH);
//============================Misc Functions=========================
void shiftSwap(byte value, int byteOrder) {
byte newByte = ((value << 4) & 0xf0) | ((value >> 4) & 0x0f);
shiftOut(dataPin, clockPin, byteOrder, newByte);
Sorry if this is not enough info, I can include more if needed.
Thanks!
[edit]Edit: I realized I had some extra stuff in the code that caused it not to compile. Fixed! (Well, the row still doesn’t work, so not really fixed.)[/edit]
