LED Matrix
Hello,
I tried to make like single raindrops on the 8x8 LED Matrix with 2 dots falling from top to bottom.
The upper LED should be a littlebit dimmed.
#include <WEMOS_Matrix_LED.h>
MLED mled(5); //set intensity=5
int y = random(0,8);
  for(int x=0;x<8;x++)
         int i = 2;
    mled.intensity=i + 2;
        mled.dot(x,y);
        int xi = x - 1;
        if (xi != -1){
        mled.intensity=i;
        mled.dot(xi,y);
        mled.display();
        delay(200);
        mled.dot(x,y,0);//clear dot
         mled.dot(xi,y,0);
        mled.display();
        delay(100);
Somehow they both still have the same intensity and i don´t know why.
Also i´m somehow stuck with my idea to make 2 raindrops fall at the same time. Could someone give me a hint?
Which 8x8 matrix are you using (link to source or schematic required)
Dont forget there are current limitations on almost all Arduino boards.
External power sources to LED arrays are quite often needed.
