LED Multiplexing help.
I have 4 tricolor led's and need to individually control them i would like to be able to PWM as well with pins left over. I thought i found a library a while back to easily do this but now i cant find it. what do you suggest.
Thank you.
This what you where looking for?
http://www.arduino.cc/playground/Learning/4051
The Adruino doesn't have enough hardware PWM outputs to do what you want.
For hardware control (plus a savings in Arduino pin requirements), you could use a TLC5940 with this library.
Or, you could do the PWM in software, using something like this library.
I realized the arduino isnt fast enough to run all colors/ lights pwm but i have started writing my own non pwm driver and it is working very well
So what principal do you use to dim LEDs without PWM then?
