led net
would it be possible to use something like this to use as an led matrix for scrolling text etc
thanks in advance
Gary
Theoretically, yes. Practically, no.
You would need quite a lot of shift registers, a huge amount of wire, a large power supply, and an insane amount of code.
Although if you had the components to build it and the time to code it, it would be possible. But it would probably take weeks, if not months, and cost hundreds, if not thousands, of dollars.
You haven't posted a link to the net, so it isn't clear whether individual LEDs in it can be addressed. I suspect not.
This high quality Christmas LED Net is perfect for decoration. The extreme temperature resistance body is ideal for decorating for both indoor and outdoor(When using outdoor, please cover the controller box especially rainy days). Also, the eight different kind of glimmering modes can create various effects according to your needs:
  1. combination 2. in waves 3. sequential 4. slo glo 5. chasing or flash 6. slow fade 7. twinkle/flash 8. steady on
this is the only information on it
garywilson4:
Chances are, there are only a handful of channels (one for each color). Not enough wires to make a matrix to display words or images I'm afraid.
garywilson4:
That is the "boilerplate" description of a standard four channel decorative light controller.
