LED not as bright on arduino
hello, i wrote a sketch shown bellow. basically when i press a button, position of servo changes and LED will indicate the position. however, the LED seems really dim. but when i upload a sketch,the LED which i connect to PIN 13, blinks brightly. is there a problem with my sketch that makes the LED not as bright?
#include <Servo.h>
Servo myservo;
int Red = 13;
int Green = 12;
const int buttonPin = 2;
int buttonState = 0;
 myservo.attach(7);
  myservo.write(90);
pinMode(buttonPin, INPUT_PULLUP);
  buttonState = digitalRead(buttonPin);
  if (buttonState == LOW) {
    myservo.write(175);
    digitalWrite(Green, HIGH);
    digitalWrite(Red, LOW);
  if (buttonState == HIGH) {
  myservo.write(90);
   digitalWrite(Green, LOW);
    digitalWrite(Red, HIGH);
thanks for the advice
Set the LED pins as outputs!
Mark
Agreed.
    myservo.write(175);
    myservo.write(90);
I'm not sure I understand your logic - buttonState is not LOW, then it must be HIGH, so there's no need to read it again, and no need to test it; a simple "else" is all that is required.
  int buttonState = digitalRead(buttonPin);
    myservo.write(175);
    myservo.write(90);
hi, thanks for the suggestion =) will take it into consideration in the future!
