knock knock knock
Dear gentlemen, I would like to ask for your help.
Although my English is short, I would like to ask for a helping hand because of the frustration of an unresolved problem.
The board used is 'Arduino Nano rp2040 connect'.
I want to control red, green, and blue of boolean type using 'switch' on the dashboard.
Red, green, blue correspond to onboard rgb led.
The source code used is below.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
while(!Serial); // Prevents sketch from running until Serial Monitor opens.
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::CONNECT, onIoTConnect);
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::DISCONNECT, onIoTDisconnect);
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::SYNC, onIoTSync);
ArduinoCloud.update();
//reads acceleration
void onRedChange() {
if(red){
digitalWrite(LEDR, HIGH); //turn on RED
else{
digitalWrite(LEDR, LOW); //turn off RED
void onGreenChange() {
if(green){
digitalWrite(LEDG, HIGH); //turn on GREEN
else{
digitalWrite(LEDG, LOW); //turn off GREEN
void onBlueChange() {
if(blue){
digitalWrite(LEDB, HIGH); //turn on BLUE
else{
digitalWrite(LEDB, LOW); //turn off BLUE
void onIoTConnect() {
Serial.println(">>> connected to Arduino IoT Cloud");
void onIoTDisconnect() {
Serial.println(">>> disconnected to Arduino IoT Cloud");
void onIoTSync() {
Serial.println(">>> Board and Cloud SYNC OK");
After opening the Serial Monitor and displaying the "SYNC OK" message, the LED's color is determined according to the value you set on the dashboard.
However, the status of the LED does not change even if I further control the 'switch' on the dashboard afterwards.
Since the variable was normally assigned to the 'switch', it is confirmed that the value has changed in the 'Variables' in the 'Setup' tab.
'Variable Permission' is also set to 'Read & Write'.
If there is a cause that can control this abnormality, please advise.
Thank you so much for reading this far.
