Hello people.
I have ran in to a brick wall with this issue. First off – the code
main
//-----PART 1-----
if(house.button1Read() || house.button2Read()) digitalWrite(LED, HIGH);
if(house.button3Read() || house.button4Read()) digitalWrite(LED, LOW);
// ----PART 2-----
int numberpulses = house.listenForIR();
if(house.IRcompare(numberpulses, ONOFFsignal))
if(house.IRcompare(numberpulses, MUTEsignal))
ButtonXRead() function (using Bounce2 library, same for other 3 buttons)
bool automatedHouse::button1Read()
button1Bounce.update();
return button1Bounce.read();
listenForIR() function
#define IRpin_PIN PIND
#define IRpin 2
#define MAXPULSE 10000
#define RESOLUTION 20
#define FUZZINESS 20
int automatedHouse::listenForIR()
currentpulse = 0;
while (1)
uint16_t highpulse, lowpulse;
highpulse = lowpulse = 0;
while (IRpin_PIN & (1 << IRpin))
highpulse++;
delayMicroseconds(RESOLUTION);
if ((highpulse >= MAXPULSE) && (currentpulse != 0))
return currentpulse;
pulses[currentpulse][0] = highpulse;
while (! (IRpin_PIN & _BV(IRpin)))
lowpulse++;
if ((lowpulse >= MAXPULSE) && (currentpulse != 0))
pulses[currentpulse][1] = lowpulse;
currentpulse++;
IRcompare() function
bool automatedHouse::IRcompare(int numpulses, int Signal[])
for (int i=0; i< numpulses-1; i++)
int oncode = pulses[i][1] * RESOLUTION / 10;
int offcode = pulses[i+1][0] * RESOLUTION / 10;
if ( (abs(oncode - Signal[i*2 + 0]) > (Signal[i*2 + 0] * FUZZINESS / 100)) || ( abs(offcode - Signal[i*2 + 1]) > (Signal[i*2 + 1] * FUZZINESS / 100)))
return false;
return true;
PROBLEM:
-Scenario 1: Using PART 1 of the main code - All 4 buttons work, LED turns on/off.
-Scenario 2: Using PART 2 of the main code - remote works, LED turns on/off.
-Scenario 3: Using all of the code - remote works, LED turn on/off; All 4 buttons don’t work, LED no reaction.
I think the problem is in the listenForIR function, but I can’t find the solution. So why don’t the buttons work if the listenForIR function is running?
Any help would be greatly appreciated!
