LED not turning off
Hi friends, i'm currently working on a RFID Door access project, and i'm having trouble to off the pin "no". i tried different pin numbers. but it does not turn off. can anyone help me please?
thanks
#include <SoftwareSerial.h>
SoftwareSerial RFID(2, 3); // RX and TX
#define PIN_SCE 11
#define PIN_RESET 12
#define PIN_DC 10
#define PIN_SDIN 9
#define PIN_SCLK 8
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
int data1 = 0;
int yes = 9;
int no = 5;
int buzzer = 6;
  pinMode(yes, OUTPUT); // for status LEDs
  pinMode(no, OUTPUT);
    digitalWrite(no, LOW);
How is the LED wired?
AWOL:
i'm not sure what you mean :sweat_smile: but ;
pin 5 -> resistor -> LED -> GND of arduino
That's what I meant; I asked because you could have had the LED wired to +5V via the resistor.
You're sure it's digital pin 5 and not A5?
have you always used a resistor?
OH! i found it. I misread actually, it's actually connected to +5V instead of GND!
Thanks mate.
hanish:
Thanks mate.
You must also have connected the LED backwards, in that case, because if the cathode, which is meant to go to ground, is tied to the +5v rail then it is in reverse polarity and will never light.
sirius631:
yes it was connected backwards. i had to swap polarity when i found that it was connected to +5V, and not GND. it was a breadboard confusion.
