LED ON/OFF at particular time without RTC
I found problem guys, maybe you could fix it.
So I decided to make LED OFF just 1 minutes after I give voltage to the arduino
by
   if(minutes > 0 && minutes < 1){
    digitalWrite(LED, LOW);
    delay(0);
    else {
But it doesnt work.
Here is the full code
#define LDR 0
#define PIR 2
#define LED 3
int pirState;
int ldrValue;
  //Serial.begin(9600);
  pinMode(LED, OUTPUT);
  pinMode(PIR, INPUT);
  //thhis is a list of int variables used in this clock program
int s=0;
int sec=0;
int hrs=0;
int minutes=0;
int initialHours = 02;//variable to initiate hours
int initialMins = 0;//variable to initiate minutes
int initialSecs = 00;//variable to initiate seconds
//this method is for seconds
int seconds()
    s = initialHours*3600;
    s = s+(initialMins*60);
    s = s+initialSecs;
    s = s+(millis()/1000);
    return s;
//this method is for hours
int hours()
    hrs = seconds();
    hrs = hrs/3600;
    hrs = hrs%24;
    return hrs;
//this method is for minutes
int mins()
    minutes = seconds();
    minutes = minutes/60;
    minutes = minutes%60;
    return minutes;
int secs()
    sec = seconds();
    sec = sec%60;
    return sec;
//this loop will conintue to keep looping so that the time can go as follows
void loop(){
    delay(0);
    else {
  ldrValue = analogRead(LDR);
  Serial.println(ldrValue);
  if (ldrValue <= 10) { // dark
      digitalWrite(LED, HIGH);
      delay(0);
  else { // ldrValue > 512
  pirState = digitalRead(PIR);
  Serial.println(pirState);
  if (pirState == HIGH) {
  else { // pirState == LOW
      delay(0);
  // The processing in the Arduino occurs faster
  // than the response from the PIR, and adding this delay
  // eliminated a flickering on the LED
  delay(0);
You think this might something to do with it ?
raschemmel:
TT
if no, how is the right code?
makanbakso:
TT
We gave you the answer. Just stare at it for a while. It's fairly obvious.
and when you'll have the code corrected according to Raschemmel's post.....
.... it still won't work !
how does "minutes" increase ?
if you never call mins() in your loop() , minutes is always 0
OP, if you haven’t picked up on this yet, if(minutes > 0 && minutes < 1){ does not include 0 OR 1. You would need something like this:
if (minutes >= 0 && minutes <= 1) { // or something like this, someone else confirm?
also, there’s a much easier way to count seconds, minutes, and hours:
if (millis() - previousMillis >= oneSecond) {
    seconds++;
    if (seconds > 59) {
      minute++;
      seconds = 0;
    if (minute > 59) {
      hours++;
      minute = 0;
aarg:
alnath:
I have stare at it for 3 days to be honest, sir.
would you?
Make a list of all the possibilities and explain why each should or shouldn't work. Do that and we'll give you the answer.
makanbakso:
would you?
No, because I would analyze it.
The numbers greater than 0 are 1,2,3....
The numbers less than 1 are 0,-1,-2,-3...
There is no number that can be in both ranges.
@chummer1010 :
nope, this is true for minutes=0 too, but you’re not too far :wink:
and in the easier “solution” you gave, there are some mistakes :
  • where does ‘oneSecond’ come from and where is it initialized ?
  • where do you initialize and then change the ‘previousMillis’ value ?
  • ‘seconds’ , ‘minute’ and ‘hours’ should also be set to 0
Allow me to explain your real problem. You are not following the standard plan for development. First you should completely specify the problem. Then you should decide on the best general methods to solve it. Finally you should write code to implement those methods.
chummer1010:
seconds++;
   if (seconds > 59) {
minute++;
     seconds = 0;
if (minute > 59) {
hours++;
     minute = 0;
Where I can place the code? Sorry, i didnt get what you mean :frowning:
raschemmel:
Make a list of all the possibilities and explain why each should or shouldn’t work. Do that and we’ll give you the answer.
Here
First, I place it inside the code at the top of the loop (before LDR and PIR sensor code) like this
void loop(){
   if(minutes < 1){
    delay(0);
    else {
    delay(0);
      delay(0);
      delay(0);
  delay(0);
Second, I have tried to place it between LDR and PIR
void loop(){
      delay(0);
   if(minutes < 1){
    delay(0);
    delay(0);
    else {
      delay(0);
  delay(0);
The third, I placed it below LDR and PIR code.
I think the problem is not about where I place the code. I dont know the additional code.
Comment above said it will never work if I not call mins(), but tbh I dont know where to place it. Seriously I am new in programming
alnath:
@chummer1010 :
I should have just posted my whole code:
#include <LiquidCrystal.h>
byte seconds = 0;
byte minute = 0;
byte hours = 0; // minutes, secs, hours,
unsigned long previousMillis = 0;
const long oneSecond = 1000UL; // for timing
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // for an lcd
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print("clock");
  lcd.clear();
    seconds++;
    if (seconds > 59) {
      minute++;
      seconds = 0;
    if (minute > 59) {
      hours++;
      minute = 0;
    } // actual counter
    char currentTime[10] = "";
    snprintf(currentTime, sizeof(currentTime), "%02d:%02d:%02d", hours, minute, seconds);
    Serial.println(currentTime); // print to serial monitor
    lcd.setCursor(0, 0);
    lcd.print(currentTime); // print time to lcd screen
    previousMillis += oneSecond; // reset for next loop
If you want to see this quickly, just comment out anything that has to do with an LCD screen, upload this, and check serial monitor.
Here
Is that what I said ?
Possibilities:
1-minutes <0
2- minutes = 0
3- minutes >0
4- minutes > 0 && minutes < 1
5- minutes > 0 && minutes = 1
6 - minutes > 0 && minutes >1
Think about it .
Which one do you want ?
aarg:
The numbers greater than 0 are 1,2,3…
The numbers less than 1 are 0,-1,-2,-3…
Oh ya -_-
but, if I change
to
if (minutes >= 0 && minutes <= 4) // or 5 or 6 until infinitife
the code still wont work
aarg:
Yes sir, I know the logic, but the problem is the sentence that I bold above
raschemmel:
Possibilities:
1-minutes <0
2- minutes = 0
3- minutes >0
Think about it .
3 because higher than 3, the LED should OFF
1 is not possible bcs there is no -1, -2 minutes
2 possible but that is not what I need
4 and 5 is not possible bcs there is no 0,1;0,2;0,3 minutes even in real world it is possible
6 :smiley:
@chummer1010
:wink:
const unsigned long oneSecond = 1000UL; // for timing
FYI:
@chummer1010 yes, now, it's OK :slight_smile: - it is always better to post the full code, especially if OP is a beginner :wink:
@makanbakso, writing the code for you is not the way to help you, is it ? As a beginner, you need to understand how your code works - One way to do that is probably to try the examples in the IDE one by one, and really understand it before you try the next one.
Possibilities:
1-minutes <0
2- minutes = 0
3- minutes >0
Does 3 meet your required time ?
4- minutes > 0 && minutes < 1 (minutes , for the purpose of this discussion is an integer and thus must be a whole number , either 0,1, 2 , 3 etc so <1 is the same as 0
Is 1 > 0 ?
Does 1 minute meet your required time stated here ?
LarryD:
@chummer1010
:wink:
FYI:
http://forum.arduino.cc/index.php?topic=396591.0
Thank you for presenting me with this information!
