LED on/off
This line produces PWM sine to PBA 7, how to make it turn on the LED at C13 when the sine is positive and turn it off when the sinus is negative?
val2 = 50 + amp / 10.0 * sin (stp * i + shift * 0.1 * 6.2831 / 360);
No it doesn't.
Please remember to use code tags when posting code
This code will turn on LED on pin 13 on positive period and turn off LED on negative period.
Hope it helps.
#include <Arduino.h>
int led = 13;
float wave = 0;
int step = 0; // 0 - 360 degrees
bool led13 = false; // Value of LED ON/OFF
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  // Calculate sine value of
  wave = sin(step * DEG_TO_RAD);
  // Turn on LED on first step of positive period
  if (wave > 0 && !led13)
    digitalWrite(led, HIGH);
    led13 = true;
  // Turn off LED on first step of negative period
  else if (wave < 0 && led13)
    digitalWrite(led, LOW);
    led13 = false;
  // Reset step
  if (step++ > 360)
    step = 0;
  delay(5);
/Mogens
ted:
[/quote]
What are you talking about?
What is the application?
What model Arduino?
Can you tell us your electronics, programming, Arduino, hardware experience?
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
The sin() function returns a value. Store that value in a variable.
 if(variable > 0)
    digitalWrite(C13, HIGH);
    digitalWrite(C13, LOW);
Really, it's about as simple as it gets.
