I have no experience with arduino, but I follow a workshop offered by an university teacher. I've build my arduino and I tried and it just now. The power led worked, but the led on pin 13 didn't blink when I used a 12v adapter. I tried again after some fiddling with the microcontroller, and it worked! Then I pushed the microcontroller onto its connector a bit more, to make sure it was in the right place, and now I can't get it to work again. I am no good at soldering, but the default blink program did work.
Does anyone have any idea what could have happened? Did I broke my microcontroller? Is it possible that i broke a connection or something like that, when I tried to attach the microcontroller more firmly?
Any help is appreciated! (this kinda sucks, I am pretty sure I did something wrong or not careful enough, but I have no idea where)...
nigelbarker:
Sounds like a dry/poor solder joint, or maybe a bent leg on the microcontroller?
Nige
I think I bent two legs of the microcontroller indeed, I de- and reattached the thing a couple of times (to try if that would make a difference) and I couldn't avoid to bent the legs on one side. It could be a poor solder joint, but in that case I must have somehow broke after the short period where it worked (and that seems unlikely to me).
Should I buy a new microcontroller?
The legs should be straight, and should slide into the socket.
Doing so isn't easily (especially the first times!) so I wouldn't be afraid asking for some help there.
A dry joint is one where little solder actually connects the two conductors, and typically fails after a tap (or a bang!).
I would get help and check things like the supply voltage actually getting to the chip, and then other critical points on the board, but you have to be careful as it is easy to let a multimeter probe slip from a single pin, and short two pins out!
Sorry, in short you need someone there physically to give you a hand imho.
Thanks for the reactions! With the help of a teacher, I finally figured out the problem: the microcontroller just wasn't working. The teacher was so kind to just give me a new one, and now it works
