LED ONtime ? OFFtime WITHOUT DELAY
Hello I'm Trying to do something like the signal below, but all the code that I have found
uses the same ON time for the OFF time using mills, What I have not found is a reference or code to handle them independently.
It's very easy to do it with the delay function, but I need to run something else, While the leds do this.
Not very experienced on this on using loops or while's yet, but anything goes.
//Activate LED's ON and OFF at independent time ONtime ? OFFtime.
//Start With LED1 and then LED2..
//Without USING DELAY..
int led1on= 500 // means that led1 will turn on 500ms
int led1off= 200 // means that led1 will turn Off 200ms
Int led2on= 400 // means that led1 will turn on 500ms
Int Led2off= 200 // means that led1 will turn on 500ms
FIRST CYCLE |SECOND CYCLE|
__________ | |__________
LED1 | ||| |
ON OFF | |
500 200 | |
________ | ________
LED2 _________________| |
_________| |
ON OFF
400 200
CYCLE STARTS AGAIN
If the LED is ON, then use one value for the interval, if it is OFF, then use another.
For multiple values, it may be easier to store the intervals in a table, and use an index incremented each time e the phase changes.
Multiblink in the Playground may do what you want.
Awol
I'm sort of new on this , any specific Indexing and or table tutorial that you recommend. I'm guessing is some sort of variable that u can use a a flag right?
Ok Marco
Let me give a shoot this weekend.
