LED output via artnet
Hello! I've built the following project:
https://learn.sparkfun.com/tutorials/sparkfun-esp32-dmx-to-led-shield/all
and connected it to WS2813 LEDs. I tested the output with FastLED cylon and it works great. I used the examples included and was able to get the ESP32 connected to wifi with an IP. I'm very familiar with Resolume and artnet, but as soon as I upload my sketch to the ESP32, the LEDs output random colors.
Original sketch:
#include <WiFi.h>
#include <WiFiUdp.h>
#include <ArtnetWifi.h> //https://github.com/rstephan/ArtnetWifi
#include <FastLED.h>
#include <ESP32Servo.h>
//Wifi settings
char ssid[] = "myDMX"; //Change these lines to an existing SSID and Password if you're trying to connect to an existing network
char password[] = "artnetnode";
// Artnet settings
ArtnetWifi artnet;
WiFiUdp UdpSend;
const int startUniverse = 0;
const int endUniverse = 0;//end Universe should be total channels/512
bool sendFrame = 1;
int previousDataLength = 0;
//Pin Definitions for ESP32 WROOM
#define CLOCK 5
#define DATA0 19
#define DATA1 18
#define DATA2 27
//Channel and Peripheral Definitions
#define NUM_LEDS 64
#define NUM_LED_CHANNELS NUM_LEDS * 3 //Ends up being 192 channels for our 8x8 LED matrix
#define PAN_CHANNEL 193
#define TILT_CHANNEL 194
CRGB matrix[NUM_LEDS];
Servo pan;
Servo tilt;
uint8_t hue = 0;
boolean connectWifi(void) //Sets our ESP32 device up as an access point
  boolean state = true;
  WiFi.mode(WIFI_AP_STA);
  state = WiFi.softAP(ssid, password);
  //Comment out the above two lines and uncomment the below line to connect to an existing network specified on lines 8 and 9
  //state = WiFi.begin(ssid, password);
  return state;
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
  // read universe and put into the right part of the display buffer
  //DMX data should be sent with the first LED in the string on channel 0 of Universe 0
  for (int channel = 0; channel < length; channel++)
    if (channel < NUM_LED_CHANNELS && channel % 3 == 0) //Only write on every 3rd piece of data so we correctly parse things into our RGB array
      matrix[channel / 3] = CRGB(data[channel], data[channel + 1], data[channel + 2]);
    else if (channel == PAN_CHANNEL - 1) //Subtract 1 due to the fact that we index at 0 and ignore the startcode
      pan.write(map(data[channel], 0, 255, 0, 160));
    else if (channel == TILT_CHANNEL - 1)
      tilt.write(map(data[channel], 0, 255, 0, 160));
  previousDataLength = length;
  if (universe == endUniverse) //Display our data if we have received all of our universes, prevents incomplete frames when more universes are concerned.
    FastLED.show();
 UdpSend.flush();
  //Fixture Hardware Declarations
  FastLED.addLeds<APA102, DATA0, CLOCK, BGR>(matrix, NUM_LEDS);
  pan.attach(DATA1);
  tilt.attach(DATA2);
  if (connectWifi())
    Serial.println("Connected!");
  artnet.begin();
  artnet.setArtDmxCallback(onDmxFrame);
  artnet.read();
My modified sketch:
#include <WiFi.h>
#include <WiFiUDP.h>
// WiFi network name and password:
const char * ssid = "redacted";
const char * password = "redacted";
const int BUTTON_PIN = 0;
const int LED_PIN = LED_BUILTIN;
// Artnet settings
ArtnetWifi artnet;
WiFiUDP UDPSend;
bool sendFrame = 1;
#define CLOCK 5
#define DATA0 19
#define DATA1 18
#define DATA2 27
#define NUM_LEDS 120
#define NUM_LED_CHANNELS NUM_LEDS * 3 //Ends up being 360 channels
uint8_t hue = 0;
// connect to wifi – returns true if successful or false if not
  int ledState = 0;
  int i = 0;
  Serial.println("");
  // Wait for connection
  Serial.println("Connecting to WiFi network: " + String(ssid));
    // Blink LED while we're connecting:
    digitalWrite(LED_PIN, ledState);
    ledState = (ledState + 1) % 2; // Flip ledState
    Serial.print(".");
    if (i > 20){
      state = false;
    i++;
  if (state){
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    Serial.println("");
    Serial.println("Connection failed.");
  return state;
  int ledState = 0;
    FastLED.show();
 UDPSend.flush();
  if (connectWifi())
    Serial.println("Connected to WiFi network: " + String(ssid));
  artnet.begin();
  artnet.read();
I noticed this in FastLED cylon:
LEDS.addLeds<WS2812,DATA_PIN,RGB>(leds,NUM_LEDS);
So I modified my sketch to change from APA102 to WS2812 or 2813, but received this error when compiling:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Adafruit ESP32 Feather, 80MHz, 256000, None, Default"
In file included from Arduino\LightLabDMXArtnetNode\LightLabDMXArtnetNode.ino:19:0:
Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
 #    pragma message "FastLED version 3.003.002"
In file included from Arduino\libraries\FastLED/FastLED.h:65:0,
Arduino\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
 #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
Arduino\LightLabDMXArtnetNode\LightLabDMXArtnetNode.ino: In function 'void setup()':
LightLabDMXArtnetNode:115:60: error: no matching function for call to 'CFastLED::addLeds(CRGB [120], int)'
   FastLED.addLeds<WS2813, DATA0, CLOCK, BGR>(leds, NUM_LEDS);
Arduino\libraries\FastLED/FastLED.h:223:129: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER, unsigned char SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB*, int, int)
  template<ESPIChipsets CHIPSET,  uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint8_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
Arduino\libraries\FastLED/FastLED.h:223:129: note:   template argument deduction/substitution failed:
Arduino\libraries\FastLED/FastLED.h:237:95: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
  template<ESPIChipsets CHIPSET,  uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
Arduino\libraries\FastLED/FastLED.h:237:95: note:   template argument deduction/substitution failed:
LightLabDMXArtnetNode:115:60: error: wrong number of template arguments (4, should be 3)
Arduino\libraries\FastLED/FastLED.h:251:113: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
  template<ESPIChipsets CHIPSET,  uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
Arduino\libraries\FastLED/FastLED.h:251:113: note:   template argument deduction/substitution failed:
Arduino\libraries\FastLED/FastLED.h:301:25: note: candidate: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
Arduino\libraries\FastLED/FastLED.h:301:25: note:   template argument deduction/substitution failed:
Arduino\libraries\FastLED/FastLED.h:307:25: note: candidate: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
Arduino\libraries\FastLED/FastLED.h:307:25: note:   template argument deduction/substitution failed:
LightLabDMXArtnetNode:115:60: error: wrong number of template arguments (4, should be 2)
Arduino\libraries\FastLED/FastLED.h:313:25: note: candidate: template<template<unsigned char DATA_PIN> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
Arduino\libraries\FastLED/FastLED.h:313:25: note:   template argument deduction/substitution failed:
Arduino\libraries\FastLED/FastLED.h:357:25: note: candidate: template<template<EOrder RGB_ORDER> class CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
Arduino\libraries\FastLED/FastLED.h:357:25: note:   template argument deduction/substitution failed:
Arduino\libraries\FastLED/FastLED.h:363:25: note: candidate: template<template<EOrder RGB_ORDER> class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB*, int, int)
Arduino\libraries\FastLED/FastLED.h:363:25: note:   template argument deduction/substitution failed:
LightLabDMXArtnetNode:115:60: error: wrong number of template arguments (4, should be 1)
Any insight?
