raschemmel:
Also, 3W/3.6V = 0.8333A per led.
12 leds in parallel is 12*0.833A = 10A
Why it is only drawing 3A instead of 10 must be due to the power source not being able to source 10A.
1.5Ahr (1500mAh) battery powering a 3A load would last 1.5Ahr/3A = 0.5 hours.
1.5Ahr battery powering a 10A load would last approximately 1.5/10 = 0.15 hours (0.15*60min/per hour = 9 minutes.
I would be interested in knowing how you arrived at 3A for 12 leds in parallel .
Do lthese leds have a series current limiting resistor ?
Have you tried powering 12 leds in parallel with a supply that can source 10A ?
The math doesn't seem to add up. I've never used high power leds like that so maybe someone who is
familiar with them can shed some light on the above. At this point I have no choice but to conclude you
are unable to source the amount of current they can draw.
There's no way 12 times 0.833A (3W/3.6V) winds up being 3A , unless you've found a way to bend the
rules of physics. The number of strings in series is not relevant to this discussion since it doesn't change
the current.
I may not be the best person to address this post since I have no experience with high power leds but
I can tell you the math doesn't add up. Maybe someone else can explain why.
Yes, I tested the board with one of those $50 Amazon bench power supplies, they are weak. But 3A at around 3.5V produced sufficient brightness for me. I understand that I have never even given it full power yet. And the batteries I've used so far tend to max out around 2 or 3 amps, I'm working with that as my number. A 1.5Ah battery would therefore give me thirty minutes of runtime, which I think is sufficient.
I will not be putting a current limiting resistor in parallel, since that would require large or powerful cooling solutions, and I do not have access to a psu that can properly power this board to it's fullest extent.
Your conclusion is correct. I do not have the resources to power the board fully, and that is fine. As far as what I HAVE done for cooling is concerned, I've found that using large solder lines to connect each LED is more than sufficient, especially after the first couple minutes of usage when the battery's ability to power the circuit is diminished.
wvmarle:
2,200 or 2,800 mAh LiPo (or even bigger - over 3,000 mAh exists) is easy enough to find in 18650 size.
Those high brightness LEDs normally have multiple LEDs on a single die, to get to the total brightness. They normally need proper heatsinking to keep from overheating (and the cooler an LED is kept, the more efficient it is).
Thanks for the reply. As per my original post, I have had 18650s from Aliexpress explode on my in the past (the batteries kindly gave me enough warning so I could put them outside each time), so I am trying to stay away from Lithium Ion. Lipos are much safer from these websites in my experience, which is why I am looking for a 1s Lipo with at least 1.5Ah of power, or a good solution to make a 2S work.
Also, I just realized, while Lithium Ion batteries usually discharge around 1 or 2C, Lipo batteries are often rated for 25-65C discharge rates. Should I be concerned when using a lipo that they will send too much current, and either kill my LEDs or have shorter battery life?
