I have to make a LED Pharmacy cross using an Arduino board and I thought of using a 16x16 P16 (16mm Pitch) Full-color LED matrix (I found many of them).
Below is the link to the matrix
But the problem is that they can’t (At least I think) be controlled by Arduino.
So, could you suggest me a LED matrix with the same characteristics that can be easily driven by a Arduino board . I’m open to all your suggestions. Thank you!
I had also seen that kind of matrix. But the problem is that I need 5 matrix to make the pharmacy cross and I do not see how to connect them with Arduino...given the type of data cable used.
Can you give some more details around what the requirements are for a pharmacy cross. i.e.
what shape is it exactly?
how big does it need to be?
what colour does it need to be?
does it need to change colour or shape?
If it doesn't change shape, you may be able to make it out of LED strip which will be much cheaper than a matrix and can still change colour if you need that. If it doesn't change colour or shape you could use single colour LED strip and then you don't need an Arduino at all, just a power supply.
ieee488:
I think it may be cheaper if you build your own cross using WS2812B RGB LED strip.
+1 - you can then make it whatever size you like and control it with one output. I think you need 3 bytes per LED, so depending on the size of your cross and density of your LEDs you might need a larger Arduino with more memory to store the patterns that you want to display.
I have to make a LED Pharmacy to buy valtrex online in pharmacy cross using an Arduino board and I thought of using a 16x16 P16 (16mm Pitch) Full-color LED matrix (I found many of them).
But the problem is that they can't (At least I think) be controlled by Arduino.
So, could you suggest me a LED matrix with the same characteristics that can be easily driven by a Arduino board . I'm open to all your suggestions. Thank you!
You asked an interesting question, would you like to add a little clarification regarding the safety of using this option?
