LED Pixel Matrix
Hi i was wondering how i would go about making the road to run LED strip light in this configuration
1, 2, 3, 4, 5, 6, 7, 8, 9, 10
11,12,13,14,15,16,17,18,19,20
21,22,23,24,25,26,27,28,29,30
31,32,33,34,35,36,37,38,39,40
41,42,43,44,45,46,47,48,49,50
and to read an animated .JIF image from the SD card shield?
Thanks
Any chance of having that question in English? What on earth do you mean?
Grumpy_Mike:
w13d8919:
Sorry auto correct I was meant to say
can you make the Arduino UNO to run RGB LED lights to make an image display from the SD card
In general yes.
What LEDs do you have? What is the image format on the SD card? What is the size of your matrix?
The tinsy web pages even have an example of running video. But low res patterns are just as easily done on a Uno.
the LED that i will be using is 5V WS2812B 5050 RGB LED Strip bought on eBay
http://www.ebay.co.uk/itm/251947626070?_trksid=p2057872.m2749.l2649&var=550817489726&ssPageName=STRK%3AMEBIDX%3AIT
which uses ground, +5v, and Din
the size might be 6x20 but could that be easily changed
The image format would be .JPG or .JIF
You can't do jpeg decompression on the Arduino there is not enough room. Most people use .bmp files as they are easy. I assume that these are not going to be needing scaling as the memory available is limited.
Other than that it should be straight forward.
Ok i could use .bpm instead
Is there a sample coed i could use it is my first time using an Arduino
What do you mean by sample code?
There are lots of examples of displaying a file off an SD card on an OLED or LCD display, so that is one part of it.
The other part is the neopixels library, you just fill the buffer with what you want and then spit it out.
However this is a medium level project not one suited for an absolute beginner.
