Ok so I have just got an Arduino Uno. I make a circuit which has 7 LED's, and connected to Digital pin 13 thru 7. it blinks each in sequence, each having a 400 Millisecond delay between On and then off. But there is one problem. I tested with my voltmeter (not included) and the voltage is too low. can I raise the voltage for my digital pin outputs?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Or a clear picture of your project.
Have you got current limit resistors fitted to each LED.
400mS is not long enough for a DMM to get reliable reading.
Tom... ![]()
Mudkip909:
Operating voltage for Arduino UNO is 5V and output voltage of an UNO is the same, as long as you stay within the controller specifications. This is enough to drive a low-power LED of any color with a couple of milliamperes.
Which color(s) are your LEDs?
Which resistor values do you use for the seven series resistors connected to your LEDs?
(deleted)
