Hello, thanks for the reply, here is our code:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include "PinStates.h"
#include "LedStates.h"
#include "Fader.h"
#include "RainbowFunction.h"
#include "SimpleRGBFunction.h"
#include "WaveFunction.h"
#include "RF.h"
const char* ssid = "........";
const char* password = "asdfghjkl";
ESP8266WebServer server(80);
const int LED_PIN = D4;
const int LED_COUNT = 125;
const int RF_OSC = 200;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LED_COUNT, LED_PIN, NEO_RGB + NEO_KHZ400);
LedStates currentLedStates(strip);
LedStates targetLedStates(strip);
Fader<LedStates> ledFader(currentLedStates, targetLedStates);
PinStates currentPinStates;
PinStates targetPinStates;
Fader<PinStates> pinFader(currentPinStates, targetPinStates);
void handleRoot() {
String message = "<html><head></head><body style='font-family: sans-serif; font-size: 12px'>Following functions are available:
message += "<a href='/rainbow?fade=3000'>/rainbow</a> a rainbow animation on LEDs
message += "<a href='/wave?r=255&g=32&b=10&fade=5000'>/wave</a> a slow wave animation on LED on base color specified by arguments: r=<0..255> g=<0..255> b=<0..255>
message += "<a href='/setleds?r=32&g=64&b=32&fade=1000'>/setleds</a> sets LEDs to the color from arguments: r=<0..255> g=<0..255> b=<0..255>
message += "<a href='/ledsoff?fade=500'>/ledsoff</a> turns off LEDs
message += "<a href='/setpins?D1=128&D2=256&D3=512'>/setpins</a> sets to any of the in arguments specified pins (D0..D8) to their PWM values (0..1023). To use them digital: 0=off, 1023=on
message += "<a href='/togglepins'>/togglepins</a> inverts all pin values form pins used before.
message += "<a href='/rf?D=6&t=200&id=28013&channel=0&on=1'>/rf</a> sends a rf code from arguments: D=<0..8> t=<0..1000> id=<0..1048575> channel=<0..2> on=<0..1>. Dx is the pin, t is the optional signal clock(default is 200, works for me)
message += "All functions except togglepins and rf support the argument 'fade' which specifies the milliseconds it takes to fade to the new specified state. ...nice blending ;-)
message += "
Syntax is as follows: http://<ip>/<command>?<argument1>=<value1>&<argument2>=<value2>&...
message += "You can click on each link to see an example.
message += "have fun -<a href='http://youtube.com/bitlunislab'>bitluni</a></body></html>";
server.send(200, "text/html", message);
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
int getArgValue(String name)
for (uint8_t i = 0; i < server.args(); i++)
if(server.argName(i) == name)
return server.arg(i).toInt();
return -1;
bool checkFadeAndSetLedFunction(LedFunction *f)
int fade = getArgValue("fade");
if(fade > -1)
targetLedStates.setFunction(f);
ledFader.start(fade);
currentLedStates.setFunction(f);
void handleRf()
const int pinNumbers[] = {D0, D1, D2, D3, D4, D5, D6, D7, D8};
int pin = getArgValue("D");
int t = getArgValue("t");
if(t == -1) t = RF_OSC;
int id = getArgValue("id");
int ch = getArgValue("channel");
int on = getArgValue("on");
String out = "rf D";
out += pin;
out += " ";
out += t;
out += " ";
out += id;
out += " ";
out += ch;
out += " ";
out += on;
pinMode(pinNumbers[pin], OUTPUT);
for(int i = 0; i < 5; i++)
rfWriteCode(pinNumbers[pin], t, id, (1 << (ch + 1)) | (on > 0? 1: 0));
server.send(200, "text/plain", out);
void setup(void){
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
//find it as http://lights.local
/*if (MDNS.begin("lights"))
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/rainbow", [](){
server.send(200, "text/plain", "rainbow");
checkFadeAndSetLedFunction(new RainbowFunction());
server.on("/wave", [](){
server.send(200, "text/plain", "wave");
WaveFunction *f = new WaveFunction();
f->init(server);
checkFadeAndSetLedFunction(f);
server.on("/setleds", [](){
server.send(200, "text/plain", "setleds");
SimpleRGBFunction *f = new SimpleRGBFunction();
f->init(server);
server.on("/ledsoff", [](){
server.send(200, "text/plain", "ledsoff");
checkFadeAndSetLedFunction(new SimpleRGBFunction());
server.on("/togglepins", [](){
server.send(200, "text/plain", "togglepins");
currentPinStates.toggle();
currentPinStates.commit();
server.on("/setpins", [](){
server.send(200, "text/plain", "setpins");
if(fade > -1)
targetPinStates.loadValues(server);
pinFader.start(fade);
currentPinStates.loadValues(server);
server.on("/pinsoff", [](){
server.send(200, "text/plain", "pinsoff");
currentPinStates.setAllTo(0);
server.on("/rf", handleRf);
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
strip.begin();
strip.show(); // Initialize all pixels to 'off'
void loop(void)
server.handleClient();
//MDNS.update();
currentLedStates.render();
if(ledFader.active)
targetLedStates.render();
if(!ledFader.fade())
currentLedStates.commit();
pinFader.fade();
Well we eventually burnt around 1m of leds in course of 5 months, trying to fix the circuit and program. First and last led controllers stopped working.
There is an video, showing the project in the first post. We wanted to do cealing lightning with leds, that are stuck between the wooden piece. Theres not much to show of the controlling box. There is just an AC wire going into Power supply and the rest is shown in the sketch.
1k = 1000uf 16v Electrolytic Capacitor
GND input in DC-DC is connected to GND output.
GND of the Leds were
nt connected to controller ground because we didnt think it was necessary, and thought that its automatically grounded, because its one circuit.
Yes, we use the converter with UNO aswell and it works perfectly fine.
We tried FastLED example program with UNO and Wemos. Uno worked perfectly, but Wemos didnt give a sign. It seemed working, but leds didnt show anything. We tried diffrent pins for wemos aswell, but maybe data is too weak?
Picture file was too big for the site:
Thanks
