Hi, I'm making a coffee table and I'd like to incorporate LED strip lighting. I'm very much a beginner with electronics and programming. I could use analog LED strips which would be an easier option. However, I'd like to explore the possibility of using digital LED strips and having some colour changing effects. After a small amount of research I've realised that, for a beginner at least, there's quite a lot to learn. Even just looking at the list of all the different Arduino boards, I don't really know where to begin. So I'll try to explain my goals in as much detail as I can, and hopefully someone can tell me if it's feasible and suitable as a beginner project and perhaps point me in the right direction.
- RGBW LED strips although RGB will suffice if necessary.
- 6 seperate strips powered from the same source. 1 strip roughly 2 metres long. 5 strips roughly 800mm long.
- Everything powered by a 5V Power bank.
- Controlled by a smartphone app using bluetooth.
I'm guessing I'll need to do some soldering, learn a bit about programming and building circuits. This is a school project so ideally I'd like to have it all working in a few weeks time.
I know there's video tutorials for doing things like this on Youtube and I'm happy to follow tutorials if that's the best approach. Just wanted to make sure that the specifics of my project are realistic.
Any help appreciated, cheers!
