LED project
Hello everyone,
We are in early stages of new project, that requires usage of electronics.
Thing is we are not common with electronics at all.
Project sounds quite simple:
2 LED lights that can pulse, pulsing needs to be variable for 30mins.
3 buttons that change intensity of light (1 - brightest, 2 - less bright, 3 - dim)
There is a need for power source that could last for at least 30 hours of usage.
On and off button and automatic turn off after 30mins.
If you have an idea what parts are needed for this project (also if you know the prices).
If you are able to produce such prototype.
If you think you can help in any other way.
Please comment or PM us!
Are you wanting to pay someone to do this for you?
Yes, we are willing to pay reasonable price for working prototype with explanations.
tasiskauno:
What does this mean - "variable for 30mins"? Blinking/pulsing an LED is of course easy enough.
Battery I assume?
Required capacity of a battery depends mostly on the power needed for those LEDs, which can be anything from 0.01W to 1,000W or more. Of course how to switch also depends on this power rating.
Not without much more detailed specifications from you.
Probably - but can say for sure only with full specifications.
