LED Project
In our project we are trying to create 2 analog LED strips that blink alternately. Some reason our LEDs are not lighting up with the code.
Tell me how you are expect the compiler to deal with pictures of code.
When you can't, do NOT post pictures of code.
Check your hardware by running the [u]Blink Example[/u]. (Of course, change the code to represent the pins you're connected to and run it multiple times , so you can check all of the outputs/colors.)
You say you want to blink alternately but your code says "fade". Which is it?
And I see 3 MOSFETS... Do you have RGB LED strips? Two regular strips requires 2 MOSFETS. Each RGB strip requires 3 MOSFETS (if you want to control the colors) so for two independently-controlled strips you need 6 MOSFETS.
Please read the post at the top of the forum on how to use the forum, you need to make it easy for people to help you, and screen shots of code is not easy to deal with nor is a scramble of wires - a drawing of the circuit diagram is easier to understand than the spagetti picture
