LED-pushbutton Flasher (Question)
Hello,
I need to use a pushbutton to light and control 8 LEDs of the same color and another LED of another color at the same time.
If the push button is pressed, the running flasher should freeze and the other color LED lights up. The flasher starts to run normally as soon as the pushbutton is released.
I have to use the command digitalWrite only 2 times max
I started with this code (used digitalWrite 3 times because I don’t know how to use it 2 times only), but how can I do it?
Please respond asap.
Serial.begin(9600); // Set the Serial Baud Rate. Note:-with Upper ‘S’
int maxOut = 13;
int minOut = 5;
for (int i = maxOut; i <= inMax - 1; i–)
pinMode(i, OUTPUT);
for (int i = maxOut; i <= inMax; i–)
digitalWrite(i, HIGH); // Turn ON the 8 RED LEDs always
pinMode(2, INPUT)
buttonState = digitalRead(2); // Read the button state
if (buttonState == HIGH) // Check: if state is high
digitalWrite(i, LOW); // Turn OFF the RED LED
digitalWrite(4, HIGH); // Turn ON the GREEN LED
Please read the first topics like "How to use forum", "How to attache code".
How is the button wired to D2?
It might work. What happends when You run the code?
Is there a special reason for that?
Sounds like an assignment designed to help you learn to solve open ended problems. How will feeding you the answer help with that?
sara1305:
This is really rude
KASSIMSAMJI:
This is really rude
Agree. As bad as "Urgent".
You seem to have a scope issue.
"I need help" or similar are also pretty silly, though I am inclined to recommend a different sort of forum or service when I see it. :astonished:
