LED PWM Dimming
I borrowed a sketch that works fine, though my attempts to modify the sketch were not so successful, I'll
post the sketch I have then explain how I would like it to work
Is there a way to define in the setup the time periods for the lighting so as to simplify editing the value?
I tried to modify how the dim period works to extend it, and whilst I got the period to run for longer it hangs half way through, I guess it’s because it’s with respect to the RTC so as the hour value changes it just stops, though I could easily be dead wrong on that.
#include <Wire.h>
#include "RTClib.h"
#include <VL53L0X.h>
LiquidCrystal_I2C lcd(0x27,20,4);
VL53L0X sensor;
 // This is the I2C address
// SainSmart LCD 16x2
//LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
// Arduino Mega 2560
const int Light1 = 2;
const int Light2 = 3;
const unsigned long HOUR = 60 * 60;
const unsigned long MINUTE = 60;
const int TARGET_BRIGHTNESS = (255 * 3) / 4;  // Target brightness is 3/4 of full
 //lcd.begin(16, 2);
 Wire.begin();
  lcd.init();
  lcd.backlight();
  sensor.init();
  sensor.setTimeout(500);
  sensor.startContinuous();
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
 return ( (val/16*10) + (val%16) );
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("***");
 lcd.setCursor(4,0);
 /////  Get time from RTC into RTCHour, RTCMinute, RTCSecond
  // Set the register pointer to 0 (Second)
 Wire.beginTransmission(DS1307_ADDRESS);
 Wire.write((byte)0);
 Wire.endTransmission();
 //  Read Second, Minute, and Hour
 Wire.requestFrom(DS1307_ADDRESS, 3);
 int RTCSecond = bcdToDec(Wire.read());
 int RTCMinute = bcdToDec(Wire.read());
 int RTCHour = bcdToDec(Wire.read() & 0b111111); //24 hour time
// write Time to LCD XX:XX:XX
 if(RTCHour < 10) {
   lcd.print("0");
lcd.print(RTCHour);
lcd.print(":");
 if(RTCMinute < 10) {
   lcd.print("0");
lcd.print(RTCMinute);
lcd.print(":");
 if(RTCSecond < 10) {
   lcd.print("0");
lcd.print(RTCSecond);
lcd.setCursor(13,0);
lcd.print("***");
 unsigned long time = RTCHour * HOUR + RTCMinute * MINUTE + RTCSecond;  // Time in seconds
// write value within the timeframe to PWM
 analogWrite(Light1,   brightness(time, 7*HOUR,                 19*HOUR));
 analogWrite(Light2,   brightness(time, 7*HOUR+30*MINUTE,                 19*HOUR+30*MINUTE));
lcd.setCursor(4,1); //Light1
if(((brightness(time, 7*HOUR,                 19*HOUR))*100/255) < 10) {
   lcd.print("0");
lcd.print((brightness(time, 7*HOUR,                 19*HOUR))*100/255);
lcd.print("%");
lcd.setCursor(8,1); //Light2
if(((brightness(time, 7*HOUR+30*MINUTE,                 19*HOUR+30*MINUTE))*100/255) < 10) {
   lcd.print("0");
lcd.print((brightness(time, 7*HOUR+30*MINUTE,                 19*HOUR+30*MINUTE))*100/255);
lcd.print("%");
byte brightness(unsigned long time, unsigned long fadeUpStart, unsigned long fadeDownStart)
 //  Mid day, light is at maximum brightness
 if (time >= fadeUpStart + HOUR  && time <= fadeDownStart)
   return TARGET_BRIGHTNESS;
 // Dawn:  fade up the light
 if (time >= fadeUpStart && time <= fadeUpStart + HOUR)  // Fading up
   unsigned long seconds = time - fadeUpStart;  // Number of seconds into the fade time
   return TARGET_BRIGHTNESS * seconds / (HOUR);  // Fade up based on portion of interval completed.
 // Evening: Fade down the light
 if (time >= fadeDownStart && time <= fadeDownStart + HOUR)  // Fading down
   unsigned long seconds = (fadeDownStart + (HOUR)) - time;  // Number of seconds remaining in the fade time
   return TARGET_BRIGHTNESS * seconds / (HOUR);  // Fade down based on portion of interval left.
 // The remaining times are night and the lights is off
 return 0;  // Shouldn't get here
Probably. It is not clear what "time periods" you are talking about, or what value you need to edit, or how you will do that.
