It seems like I cannot upload sketches anymore. It worked without any trouble before. After I power up or reset the board, the LED at PIN 13 is rapidly blinking. I think it was caused by uploading a sketch with a large static array.
From reading other posts like http://forum.arduino.cc/index.php/topic,26864.0.html, I assume that I broke my bootloader. Is this assumption correct?
I tried a few tricks like holding the reset button and releasing it right before the upload procedure etc. But it didn't seem to work. Board and Serial Port are selected correctly. What are my options at this point?
This is the output that I get:
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/lucas/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbserial-A4007mpn
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
My setup:
Computer: Mac OS X 10.8.5
Board: Arduino Duemilanove
