Led remains turned on... Help
Hello there!
I have wrote a program for my robot that uses distance sensors and i want it so that when the something is detected the led turns on and when not its low… However with my current program the led remains lit no matter what i do.
Snippet of code including led:
 if(distance < 7 && distance > 0 ){
     digitalWrite(led, HIGH);
     motor.write(90);
  }else{
    digitalWrite(led, LOW);
      if (Sped == 100){
        motor.write(30);
      }else{
        motor.write(90);
entire code:
#include <Servo.h>
#define trig 12
#define echo 13
#define led 10
Servo myServo, motor;
String pos;
String sped;
String readString;
void setup(){
 Serial.begin(19200);
 myServo.attach(10);
 motor.attach(9);
 pinMode(trig, OUTPUT);
 pinMode(echo, INPUT);
 pinMode(led, OUTPUT);
void loop(){
  int duration, distance;
 digitalWrite(trig, LOW);
  delayMicroseconds(5);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echo, HIGH);
  distance = duration/58.2;
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == '*') {
      //do stuff
      int ind1 = readString.indexOf(',');  //finds location of first ,
      pos = readString.substring(0, ind1);
      int ind2 = readString.indexOf(',', ind1+1);
      sped = readString.substring(ind1+1, ind2);
      int Pos = pos.toInt();
      int Sped = sped.toInt();
      if (Pos == 125){
      Pos = 90;
      }else if( Pos > 125){
      Pos = map(Pos, 126, 225, 90, 160);
      }else if ( Pos < 125){
      Pos = map(Pos, 124, 30, 90, 20);
      }else;
      Pos = Pos;
      myServo.write(Pos);
     motor.write(90);
  }else{
      if (Sped == 100){
        motor.write(30);
      }else{
        motor.write(90);
      readString = "";
      pos = "";
      sped = "";
    }else{
      readString += c;
If someone could idicate to me why it might be staying on that would be much apreciated!
Also the wiring is correct because i did some simple programs to test it and its fine.
Hello,
  • deleted my stupid comment, sorry I'm tired :D -
Hahaha i didn't even see it so don't worry!
lele_gricc: Hahaha i didn't even see it so don't worry!
That's not fair. Whenever I make a stupid comment, EVERYONE sees it before I realise.
And I'm quite frequently "tiered" ;)
Hahaha sucks....
But anyways i solved the problem
I attached myServo and the led to the same pin in the software.... ::)
lele_gricc: I attached myServo and the led to the same pin in the software.... ::)
Sounds like you're "tired" too :)
