led remote control
Hello to all!
For some days I'm going crazy for 8 LEDs turn on and off remotely!
I found a sketch that was right for me but that he could control only one LED as I can do to control 8?
This is the code:
include <String.h>
#include <SPI.h>
#include <Ethernet.h>
Simple Ethernet Test
Arduino server outputs simple text to browser
and controlling LED with simple checkbox
The circuit:
* Arduino Duemilanove
* Arduino Ethernet shield
* Basic FTDI breakout 5V
* LED connected to GND and digital pin 4 via resistor
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 123 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
int ledPin = 9; // LED pin
char link[]="http://www.ioscripto.it"; //link data
String readString; //string
boolean LEDON = false; //LED status flag
void setup(){
Ethernet.begin(mac, ip, gateway, subnet);
pinMode(ledPin, OUTPUT);
void loop(){
if (client) {
  boolean currentLineIsBlank = true;
  while (client.connected()) {
    if (client.available()) {
      char c = client.read();
        readString.concat(c); //store characters to string
      //if HTTP request has ended
      if (c == '\n' && currentLineIsBlank) {
         Serial.print(readString);
        if(readString.indexOf("L=1") > 0) {//lets check if LED should be lighted
          //led has to be turned ON
          digitalWrite(ledPin, HIGH); // set the LED on
          LEDON = true;
          }else{
          //led has to be turned OFF
          digitalWrite(ledPin, LOW); // set the LED OFF
          LEDON = false;
        // now output HTML data starting with standart header
        client.println("Content-Type: text/html");
        client.println();
        // inizializzo pagina (da togliere se uso ajax)
        client.print("<html><head><title>ARDUINO Controllo Led via WEB</title><meta http-equiv='Content-Type' content='text/html; charset=iso-8859-1' ></head><body>");
        //send first heading
        client.println("<h1>LED CONTROL by internet connection</h1>");
        client.println("<hr />");
        client.println("<h1>LED control</h1>");
        //address will look like http://192.168.1.110/?L=1 when submited
        client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
<input type=submit value=submit></form>");
        client.println("
        //printing LED status
        client.print("<span>LED status: </span>");
          if (LEDON) {
          	client.println("<span style='color:green'>ON</span>");
          	client.println("<span style='color:grey'>OFF</span>");
        // chiudo pagina da togliere se uso ajax
        client.println("</body></html>");
        //clearing string for next read
        readString="";
        //stopping client
        client.stop();
        } //if c == /n .... devo capire che significa
    } // if client available
  } // while client connesso
} // if client
} //loop
This is the code:
The code does something if the GET request contains L=1. Otherwise, it sends back the original page.
You need more input objects on the form, with different names. The, the submit action will send more data back to the Arduino. Printing the data that you get from the client is generally a good thing. Stabbing in the dark is not.
