LED roulette
Hi guys!
I'm just beginning to understand programing arduino and I'm making a simple roulette with four leds and I want to make them stop randomly. At the moment it just stops at the same place every time. Can you please guide me?
Here is my code:
const int buttonPin = 2;
int lightpins[4] = {
  10,11,12,13};
int state=0;
  pinMode (buttonPin,INPUT);
  pinMode (lightpins[0],OUTPUT);
  pinMode (lightpins[1],OUTPUT);
  pinMode (lightpins[2],OUTPUT);
  pinMode (lightpins[3],OUTPUT);
  digitalWrite (lightpins[0],LOW);
  digitalWrite (lightpins[1],LOW);
  digitalWrite (lightpins[2],LOW);
  digitalWrite (lightpins[3],LOW);
void loop ()
  int reading = digitalRead (buttonPin);
  int blinktime=20;
  boolean done;
  if (reading == HIGH)
    if (state==0)
      state=1;
      done=false;
      blinktime=20;
      blinktime += random(3);
      while (!done)
        for (int j=0;j<4;j++)
          blinktime += 4;
          digitalWrite(lightpins[j],HIGH);
          if (blinktime>200)
            done=true;
          delay(blinktime);
          digitalWrite(lightpins[j],LOW);
          delay(blinktime);
    state=0;
So where and how do you plan to seed your RNG (random number generator)? If it always starts the same (default) then it will always run the same.
A common way of seeding the PRNG is to put this in startup()
randomSeed(analogRead(0));
That way the sequence starts at a place determined by the floating analog input, so at most 1024 different starting points, but may be good enough for your application.
I was hoping i could use random in the end somehow Like i said, im new to programming so i'm struggling a bit.
Thank you for the reply, i'll try with that!
