First post, so please forgive me if I do anything wrong! I'm trying to get a simple LED clock working with a ds1307 and 4 discrete common anode 7 segment displays. The ds1307 is working fine and i can get the serial output of the time and date. I have written some code to display on the LED's and this works as well. I have managed to separate the minutes in to units and tens - and also to separate the hours similarly. This all works fine when I put this to serial output, however, when i pass the variables to the LED's all i get is zero's. Has anyone any idea please. I'm sure i'm doing something stupid! Please excuse the sloppy code.
// #include <Wire.h>
#include "RTClib.h"
//#if defined(ARDUINO_ARCH_SAMD) // for Zero, output on USB Serial console
//#define Serial SerialUSB
//#endif
int HOUR, MINUTE;
int units, tens, hundreds, thousands;
int COUNT=0;//count integer for 0-9 increment
RTC_DS1307 rtc;
// a b c d e f g
const byte pins[] = {2, 3, 4, 5, 6, 7, 8};
const byte digits[] = {
//gfedcba
0b0111111, // 0
0b0000110, // 1
0b1011011, // 2
0b1001111, // 3
0b1100110, // 4
0b1101101, // 5
0b1111101, // 6
0b0100111, // 7
0b1111111, // 8
0b1101111 // 9
void displayNumber(byte number) {
number = number % 10; // hold the number within array bounds
byte d = digits[number];
for (byte i = 0; i < sizeof(pins); i++) {
digitalWrite(pins[i], bitRead(d, i)); // turn segments on or off
void setup () {
// while (!Serial);
// Serial.begin(57600);
// if (! rtc.begin()) {
// Serial.println("Couldn't find RTC");
// while (1);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); //set time from computer
//rtc.adjust(DateTime(2014, 1, 21, 14, 41, 10));
pinMode(2, OUTPUT); // Seg A
pinMode(3, OUTPUT); // Seg B
pinMode(4, OUTPUT); // Seg C
pinMode(5, OUTPUT); // Seg D
pinMode(6, OUTPUT); // Seg E
pinMode(7, OUTPUT); // Seg F
pinMode(8, OUTPUT); // Seg G
pinMode(9, OUTPUT); // Digit 1
pinMode(10, OUTPUT); // Digit 2
pinMode(11, OUTPUT); // Digit 3
pinMode(12, OUTPUT); // Digit 4
#define segA 2// connecting segment A to PIN2
#define segB 3// connecting segment B to PIN3
#define segC 4// connecting segment C to PIN4
#define segD 5// connecting segment D to PIN5
#define segE 6// connecting segment E to PIN6
#define segF 7// connecting segment F to PIN7
#define segG 8// connecting segment G to PIN8
void loop () {
DateTime now = rtc.now();
HOUR = now.hour();
MINUTE = now.minute();
//Serial.print(thousands);
//Serial.print(hundreds);
//Serial.print(':');
//Serial.print(tens);
//Serial.print(units);
//Serial.print(unitsD);
//Serial.println();
//delay(1000);
if (HOUR < 10)
hundreds = HOUR;
thousands = HOUR/10;
else if (HOUR >= 10 && HOUR < 24)
hundreds = HOUR % 10;
thousands = HOUR / 10;
if (MINUTE <= 9)
units = (MINUTE);
tens = (MINUTE/10);
else if (MINUTE > 9 && MINUTE <= 60)
units = (MINUTE % 10);
tens = (MINUTE / 10);
digitalWrite(9, HIGH);
displayNumber(units);
delay (5);
digitalWrite(9, LOW);
digitalWrite(10, HIGH);
displayNumber(tens);
delay (5);
digitalWrite(10, LOW);
digitalWrite(11, HIGH);
displayNumber(hundreds);
delay (5);
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
displayNumber(thousands);
delay (5);
digitalWrite(12, LOW);
