So i have 6 LED, 3 on the right 3 on the left,
2 of the Anode (both of the left led/ middle ones / right ones) are connected to each other,
the right part of the LED´s or connected to a -Pol and the left side to a different -Pol with a 220Ohm Resistor.
Then i have 2x Transistors, the Bases are connected to an Arduino Pin, the Emitter to a 3rd -Pol with a 1kOhm Reisitor and each Collector to one of the -Pols from the LED´s.
I use that to Control each LED with a small Numbers of Pins.
Now the Problem is that the LED´s which are switched to LOW are still lighting a bit.
Now i have the
Emitter connected to the Arduino Pin
Base is "creating" a -Pol for the LEDs
Colector is connected with a 1k Ohm Resistor the the default -Pol.
