It's my first post here and i'm sorry for some noob questions
Anyway, i'm trying to build this LED sensing stuff as described in Playground "LEDsensor" page and everything worked fine when i used a breadboard and wires.
When i made a simple small one-layer pcb with a connector and led everything stopped working.
Is that a problem with pcb track capacity? can it be solved easily or should i better switch to another scheme (maybe a code with analog pin involved or interfacing a ready built sensor)?
i’ve got an arduino nano (3.0) plugged into a breadboard. when i simply plug wires (about 10cm) into breadboard and connect two leds to them - the wjole thing works great. When i plug wires in this “board” instead of just LEDs - the led between that 2 & 3 pins constanty lits as if it gets LOW value in that “if (j<30000)” loop in the code…
Sorry for my messy explanation and thanks for answering.
I'm using the code from the example that applies the reversed voltage to led through arduino pins 2 and 3. 2 is cathode and 3 is anode. then i connect that two arduino pins to one of the leds on the board and connect a +5V dc through a 100 Ohm resistor on a breadboard to another LED. no matter which led i use for sensing i get just two leds constantly lit.
