LED sequence not working; temperature related
Hello,
I’m having a bit of trouble getting 3 LEDs to light up in accordance to the temp. I’ve got 3 LEDs, and three temp ranges, which will be adjusted once this has been set up, these being 7, 8 and 9.
The low (7) and medium (8) temp works but the higher temp (9) never does. I’ve tried the code a variety of ways, use different else if/else comments but it never lights up, the middle LED (8) remains on instead of switching.
My code is below. This is from a project online which I’m using for experience and then plan to modify as I go along.
Thanks in advance
#include <LiquidCrystal.h>
#include <DHT.h>
#include "DHT.h"
#define DHTPIN A0     // what pin we're connected to
#define DHTTYPE DHT22   // DHT 22
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
DHT dht(DHTPIN, DHTTYPE);
  for (int DigitalPin = 7; DigitalPin <= 9; DigitalPin++)
  pinMode(DigitalPin, OUTPUT);
  lcd.begin(16,2); //16 by 2 character display
dht.begin();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Temp: ");
  //lcd.print(t);
  lcd.print(t,1);
  lcd.print("\337C");
  lcd.setCursor(0,1);
  lcd.print("Humid: ");
  //lcd.print(h);
  lcd.print(h,1);
  lcd.print("%");
  //the 3-led setup process
  if (t<=22)
  digitalWrite(7, HIGH);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  else if (t>23)
  digitalWrite(8, HIGH);
  digitalWrite(7, LOW);
  else if (t>=25)
  digitalWrite(9, HIGH);
"t>23" satifies the condition of t>23 and t>=25 so the t>=25 condition never gets checked.
Tweak your tests a bit.
Blackfin:
Ah okay! That makes sense. I've used a bunch of different temps, bigger ranges between each one but no matter what, it never changes.
Should I adjust the code? I know this is incredibly basic but I'm going around in circles
Is it anything to do with this?
exiledyorkie:
Ah okay! That makes sense. I’ve used a bunch of different temps, bigger ranges between each one but no matter what, it never changes.
Should I adjust the code? I know this is incredibly basic but I’m going around in circles
Try this:
  if (t<=22)
  else if (t>22 && t<25)
  else if (t>=25)
Your pin initialization is fine though a bit unorthodox. It can be confusing for you (or someone else) to look at your code and see non-descriptive things like digitalWrite(9,HIGH).
Consider naming the pins reasonably descriptively:
#define NUM_LEDS        3
const byte pinLED_LOW = 7;
const byte pinLED_MED = 8;
const byte pinLED_HIGH = 9;
You can put those names into an array:
const byte pinArray[NUM_LEDS] =
    pinLED_LOW,
    pinLED_MED,
    pinLED_HIGH
and then use that to set up the pinModes, like you did already but a bit more clearly:
    for( int i=0; i<NUM_LEDS; i++ )
        pinMode( pinArray[i], OUTPUT );
Then, when assigning the states to the LEDs, use their descriptive names:
    if (t<=22)
        digitalWrite(pinLED_LOW, HIGH);
        digitalWrite(pinLED_MED, LOW);
        digitalWrite(pinLED_HIGH, LOW);
        digitalWrite(pinLED_LOW, LOW);
        digitalWrite(pinLED_MED, HIGH);
    else if (t>=25)
        digitalWrite(pinLED_HIGH, HIGH);
You could get cocky and use a feature of C to let you do the conditional for each LED in one line:
    digitalWrite(pinLED_LOW, (t<=22)?HIGH:LOW );
    digitalWrite(pinLED_MED, (t>22 && t<25)?HIGH:LOW );
    digitalWrite(pinLED_HIGH, (t>=25)?HIGH:LOW );
Blackfin:
Try this:
  if (t<=22)
  else if (t>=25)
#define NUM_LEDS        3
    pinLED_LOW,
    pinLED_MED,
    pinLED_HIGH
    if (t<=22)
    else if (t>=25)
Thank you so much for the in-depth response. That has helped massively.
I’ve just changed the code as you have suggested and it worked perfectly. Looking at it, now it makes perfect sense, as I did not set the correct boundaries. A learning curve there.
Thank you for the extra advice with naming the leds etc. Now I know it works I will go forward with that, as I did find it a little confusing to follow. But reading some code is beginning to get a bit easier.
Again, thank you and I’ll give that a crack now.
I’ve copied the code across and I get the following error for the code above. No idea with this one. I get this error
Arduino: 1.8.8 (Windows 10), Board: “Arduino/Genuino Uno”
Temp_Humidity_Sensor_LCD_Display_with_LED_Indicator:24:5: error: expected unqualified-id before ‘for’
for ( int i=0; i<NUM_LEDS; i++ )
Temp_Humidity_Sensor_LCD_Display_with_LED_Indicator:24:20: error: ‘i’ does not name a type
Temp_Humidity_Sensor_LCD_Display_with_LED_Indicator:24:32: error: ‘i’ does not name a type
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
Please post your code
AWOL:
My original is in the first post but here is the amended one. The three LEDs work accordingly now, thank you but I get an error displayed for the term ‘for’ but I can understand why.
#include <DHT.h>
#include "DHT.h"
#define NUM_LEDS        3
    pinLED_LOW,
    pinLED_MED,
    pinLED_HIGH
dht.begin();
  lcd.clear();
  lcd.setCursor(0,0);
  //lcd.print(t);
  lcd.print(t,1);
  lcd.print("\337C");
  lcd.setCursor(0,1);
  //lcd.print(h);
  lcd.print(h,1);
  lcd.print("%");
  if (t<=22)
  else if (t>=25)
Move the for loop:
into setup(). It replaces your existing loop:
Blackfin:
Move the for loop:
Apologies, I do not understand. Remove the original section of ‘DigitalPin’ ? as I’ve done what I thought you meant and it doesn’t work, so I’ve misunderstood.
Try this:
#include <DHT.h>
#include "DHT.h"
#define NUM_LEDS        3
    pinLED_LOW,
    pinLED_MED,
    pinLED_HIGH
    dht.begin();
  lcd.clear();
  lcd.setCursor(0,0);
  //lcd.print(t);
  lcd.print(t,1);
  lcd.print("\337C");
  lcd.setCursor(0,1);
  //lcd.print(h);
  lcd.print(h,1);
  lcd.print("%");
  if (t<=22)
  else if (t>=25)
Blackfin:
Try this:
#include <DHT.h>
#include “DHT.h”
#define DHTPIN A0    // what pin we’re connected to
#define NUM_LEDS        3
    pinLED_LOW,
    pinLED_MED,
    pinLED_HIGH
    dht.begin();
  // Sensor readings may also be up to 2 seconds ‘old’ (its a very slow sensor)
lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(“Temp: “);
  //lcd.print(t);
  lcd.print(t,1);
  lcd.print(”\337C”);
  lcd.setCursor(0,1);
  lcd.print(“Humid: “);
  //lcd.print(h);
  lcd.print(h,1);
  lcd.print(”%”);
  if (t<=22)
  else if (t>=25)
Again, thank you! That worked. I just required some spoon feeding. Brilliant!
