All-
So I’m working on LED Sequencer firmware for my Lilypad clone with an on-board TLC5940. The idea is that the user creates “banks” of one (or more) LEDs and an interval for each bank. At the desired time, the bank will turn on (or off) as needed.
These banks have already been defined in EEPROM (this is a stripped-down version of my code; the actual software supports a “program mode” where it will allow the user to configure the EEPROM serially via a Visual Basic .net program) and are read in at run-time.
I setup a pattern where I defined 6 banks of 2 LEDs, each firing at 1/2, 1, 2, 4, 8, and 16 seconds (a 6bit binary counter). The interval is defined in 1/10 seconds, with a max of 9999 (16 minutes and some change).
THE PROBLEM: The first bank turns on, but doesn’t turn off after 1/2 second. It only blinks for 1/2 second every 10 seconds or so (if that). The other 5 banks work fine.
THE (APPARENT) SOLUTION: I added debugging statements to figure out why it didn’t work and guess what - the problem disappeared!
Finally I messed around with various combinations to discover that a “delay(2)” in the addEvent method seems to be the easiest and solution with less impact (adding the debugging code throws off the animation).
So uncommenting the define for EFFIN_BUGGY_CODE OR DEBUG_CHECK will cause the problem to disappear.
Also if I change the delay at the bottom of loop() to 25 millis or more the problem doesn’t appear either (but the animation isn’t as smooth).
Basically adding sufficient debug code to see what is going on causes the problem to disappear.
So I’m assuming this is some sort of timing issue but it could be my buggy code, hence the reason for my post.
First up, the main program
// Simple LED Sequencer code
#include "Events.h"
#include <Tlc5940.h>
#include <EEPROM.h>
#define MAX_BRIGHTNESS 40 // max LED brightness
#define EEPROM_BASE 100 // Start of bank data
#define SIZE_OF_EEPROM 4 // size of bank data in EEPROM
Events sequenceList; // event queue
int bankOffset = 0;
sequenceList.init(); // Initialize event list
// Fetch data from EEPROM. Start w/ number of banks
int numberBanks = EEPROM.read(EEPROM_BASE);
// For each bank, pull sequence info
for (int indx=0; indx < numberBanks; indx++) {
// Pull the data for each bank from the EEPROM
// First Determine the offset into EEPROM
int spot = EEPROM_BASE + 1 + (SIZE_OF_EEPROM * indx);
int bankNo = EEPROM.read(spot);
int numberLEDs = EEPROM.read(spot + 1);
// handle interval a bit differently since it's really an integer
int interval = EEPROM.read(spot + 2) << 8; // high byte
interval += EEPROM.read(spot + 3); // low byte
// Now add these entries into the event list and let's go!
sequenceList.addEvent( interval, bankNo, bankOffset, numberLEDs );
// adjust bank offset
bankOffset += numberLEDs;
// Initialize TLC5940 and turn all channels off
Tlc.init(0);
// Main program loop
// Pretty much idle here waiting for the next event to expire. We toggle
// the LED state, delete the event, and re-add it with a new eventTime.
if (sequenceList.checkEvent()) {
// Timer expired! Extract details
int bankNumber = sequenceList.getBankNumber();
int bankOffset = sequenceList.getBankOffset();
int interval = sequenceList.getInterval();
int numberLEDs = sequenceList.getNumberLEDs();
boolean lights = false;
// Now delete and re-add the event back so we can keep things on schedule
sequenceList.deleteEvent();
sequenceList.addEvent(interval, bankNumber, bankOffset, numberLEDs);
// Check first LED in bank to see if we need to turn everything off or on
if (Tlc.get(bankOffset) == 0)
lights = true;
// Update the bank as needed
for (int indx = bankOffset; indx < (bankOffset + numberLEDs); indx++) {
if (lights)
Tlc.set(indx, MAX_BRIGHTNESS);
Tlc.set(indx, 0);
// Update the display
Tlc.update();
else {
// Let's kill some time here
delay(2);
Here is the included “Events” class.
// Events
// Simple event handler for LED sequencer
#include <Wprogram.h>
// Total number of events possible
#define MAX_EVENTS 16
class Events {
private:
// Event structure
typedef struct {
unsigned long eventTime; // Event deadline
int interval; // Actual event time period
int bankNumber; // bank number
int bankOffset; // bank offset (0-16)
int numberLEDs; // Total number of LEDs in bank
} event;
event eventList[MAX_EVENTS]; // Current event list
int numberEvents; // Number events in list
public:
void init(void); // initialize the object
// Add an event to the list
boolean addEvent(int interval,
int bankNumber,
int bankOffset,
int numberLEDs);
// Check to see if the current event has expired
boolean checkEvent(void);
// Fetch event details
int getInterval(void) { return eventList[0].interval;}
int getBankNumber(void) { return eventList[0].bankNumber;}
int getBankOffset(void) { return eventList[0].bankOffset;}
int getNumberLEDs(void) { return eventList[0].numberLEDs;}
// How many events are in the queue?
int getNumberEvents(void) { return numberEvents;}
// Delete the current event
boolean deleteEvent(void);
void dumpEvents(void);
// Class implementation follows
// Initialize object
void Events::init(void) {
numberEvents = 0;
// Add an event to the queue (ok, it's an array). Note this will insert items
// in chronological order of expiration
boolean Events::addEvent(int interval, int bankNumber, int bankOffset, int numberLEDs) {
int indx = 0;
boolean found = false;
boolean done = false;
unsigned long eventTime = millis() + (unsigned long)interval * 100UL;
// Make sure there is room at the inn
if (numberEvents == MAX_EVENTS)
return false;
#define EFFIN_BUGGY_CODE 1
#ifdef EFFIN_BUGGY_CODE
// I can't figure out how to make this work consistently without a small delay
// here.
delay(2);
#endif
// Locate the position in the array
for (indx = 0; (indx < numberEvents) && !found; indx++) {
found = (eventTime < eventList[indx].eventTime);
if (found) {
// Found a spot in the array. Move the existing events up one spot
// First adjust indx (since it will be off by one)
indx--;
// Now move items up one to leave a spot
for (int spot=numberEvents; spot > indx; spot--) {
eventList[spot] = eventList[spot - 1];
// Now insert the new event
eventList[indx].interval = interval;
eventList[indx].eventTime = eventTime;
eventList[indx].bankNumber = bankNumber;
eventList[indx].bankOffset = bankOffset;
eventList[indx].numberLEDs = numberLEDs;
else {
// didn't find it. Simply add to the end of the list
eventList[numberEvents].interval = interval;
eventList[numberEvents].eventTime = eventTime;
eventList[numberEvents].bankNumber = bankNumber;
eventList[numberEvents].bankOffset = bankOffset;
eventList[numberEvents].numberLEDs = numberLEDs;
// Bump event counter
numberEvents++;
return true;
boolean Events::checkEvent(void) {
if (numberEvents == 0)
return false;
//#define DEBUG_CHECK 1
#ifdef DEBUG_CHECK
if (millis() >= eventList[0].eventTime) {
if (eventList[0].bankNumber == 1) {
Serial.print("expired @ ");
Serial.println(millis());
#endif
return (millis() >= eventList[0].eventTime);
boolean Events::deleteEvent(void) {
// make sure the list is populated
return false;
// If there was only one we are done here
if (--numberEvents == 0)
return true;
// Move the rest down a bit
for (int indx=1; indx <= numberEvents; indx++) {
eventList[indx - 1] = eventList[indx];
return true;
Ideas? Things I can do better? So far, the only thing I’ve thought of to improve the code’s speed would be to keep the current LED state in the event structure (since I’m sure it’s faster to pull out a boolean and flip it than to query the TLC5940 over SPI).
Thanks in advance,
Brad (KF7FER)
PS Oh yeah, I’ve tried this with faster animations (1/10, 1/5, 2/5, 4/5, 1.6, and 3.2 seconds) as well as slower (1,2, 4, 8, 16, and 32 seconds) and the problem persists.
