Hello!
I am trying to build an 8 step sequencer and I have to use multiplexers. I can't figure out why I can't replace the delay() function with the millis() function which determines the speed of the sequence. If I run my code, all the LEDs turn on.
Sequencer.cpp:
#include "Sequencer.h"
#include "Display.h"
Sequencer::Sequencer() : ADCFilter(60, 0),
Enc1(17, 18),
patchCord1(waveform[1], envelope[1]),
patchCord2(waveform[2], envelope[2]),
patchCord3(waveform[3], envelope[3]),
patchCord4(waveform[0], envelope[0]),
patchCord5(envelope[3], 0, mixer1, 3),
patchCord6(envelope[2], 0, mixer1, 2),
patchCord7(envelope[0], 0, mixer1, 0),
patchCord8(envelope[1], 0, mixer1, 1),
patchCord9(mixer1, 0, i2s1, 0),
patchCord10(mixer1, 0, i2s1, 1)
for (int i{0}; i < 4; ++i)
envelope[i].attack(attack[i]);
envelope[i].decay(decay[i]);
envelope[i].sustain(sustain[i]);
envelope[i].release(release[i]);
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(defaultVolume);
attack.fill(defaultDecayValue);
decay.fill(defaultDecayValue);
sustain.fill(defaultSustainValue);
release.fill(defaultSustainValue);
amplitude.fill(defaultVolume);
for (unsigned int i{0}; i < 4; ++i)
mixer1.gain(i, defaultVolume);
waveform[i].begin(WAVEFORM_ARBITRARY); // WAVEFORM_SINE expands to 0 WAVEFORM_ARBITRARY expands to 4
waveform[i].amplitude(amplitude[i]);
waveform[i].frequency(frequency[i]);
pinMode(m_stepLEDPin[i], OUTPUT);
pinMode(m_stepButtonPin[i], INPUT_PULLUP);
float Sequencer::getBPMInterval()
pointerToAnalogValues = analogPotiReader();
// Serial.println(*(pointerToAnalogValues + 1));
int RawValue = *pointerToAnalogValues;
ADCFilter.Filter(RawValue);
if ((millis() - m_lastMillis) > m_BPMInterval && ADCFilterBefore != ADCFilter.Current() && (ADCFilterBefore - ADCFilter.Current() > m_AnalogThreshold))
m_lastMillis = millis();
ADCFilterBefore = ADCFilter.Current();
// subtract the last reading:
total = total - readings[readIndex]; // Alle analoge Inputwerte zusammenaddiert, wobei der Wert der neuen Loop abgezogen wird (zieht den nullten Wert ab)
// read from the sensor:
readings[readIndex] = RawValue;
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
if (readIndex >= numReadings)
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
average_bpm = mapper(average, 1.0, 1023.0, minBPM, maxBPM);
if (average_bpm != average_bpm_alt)
average_bpm_alt = average_bpm;
float m_interval = (60.0 / average_bpm) * 1000.0;
return m_interval;
unsigned int Sequencer::counter(float interval) // Returns the current position
if ((millis() - m_lastMillis) > getBPMInterval()) // m_interval = 1000 ---> 60 bpm , m_interval = 500 ---> 120bpm
m_step++;
if (m_step == m_STEPNUM)
m_step = 0;
return m_step;
void Sequencer::muxInit()
pinMode(pin_Out_S0, OUTPUT);
pinMode(pin_Out_S1, OUTPUT);
pinMode(pin_Out_S2, OUTPUT);
pinMode(ledMuxCom, OUTPUT);
pinMode(buttonMuxCom, INPUT_PULLUP);
pinMode(potiMuxCom, INPUT);
void Sequencer::muxUpdate()
unsigned int stepCounterBefore = 0;
unsigned int stepCounter = counter(getBPMInterval());
digitalWrite(pin_Out_S0, bit1[stepCounter]);
digitalWrite(pin_Out_S1, bit2[stepCounter]);
digitalWrite(pin_Out_S2, bit3[stepCounter]);
if (stepCounter != stepCounterBefore)
stepCounterBefore = stepCounter;
digitalWrite(ledMuxCom, HIGH);
// delay(200);
//buttonMuxState[stepCounter] = digitalRead(buttonMuxCom);
int *Sequencer::analogPotiReader()
for (unsigned int i{0}; i < 8; ++i)
digitalWrite(pin_Out_S0, bit1[i]);
digitalWrite(pin_Out_S1, bit2[i]);
digitalWrite(pin_Out_S2, bit3[i]);
potiMuxState[i] = analogRead(potiMuxCom);
/* Serial.print(i);
Serial.print(":");
Serial.print(potiMuxState[i]);
Serial.print(", "); */
return potiMuxState;
void Sequencer::update(int16_t *arrayInput)
analogPotiReader();
wave1Values = arrayInput;
muxUpdate();
stepButtons();
stepLED();
Sequencer.h:
#ifndef Sequencer_h
#define Sequencer_h
#include <Encoder.h>
#include <array>
#include <Audio.h>
#include <Wire.h>
#include <MegunoLink.h>
#include <Filter.h>
class Sequencer
public:
Sequencer();
void start();
void stop();
unsigned int counter(float interval);
void stepButtons();
void stepLED();
void update(int16_t *arrayInput);
float getBPMInterval();
void muxUpdate();
float mapper(float x, float in_min, float in_max, float out_min, float out_max);
void muxInit();
int *analogPotiReader();
int _deflectionRate;
int frequency1 = {160};
int frequency2 = {200};
int frequency3 = {140};
int frequency4 = (110);
ExponentialFilter<long> ADCFilter;
std::array<float, 4> attack;
std::array<float, 4> decay;
std::array<float, 4> sustain;
std::array<float, 4> release;
std::array<float, 4> amplitude;
std::array<int, 4> frequency{{frequency1, frequency2, frequency3, frequency4}};
std::array<int, 4> m_stepLEDPin{{3, 4, 5, 6}};
std::array<int, 4> m_stepButtonPin{{0, 1, 14, 15}};
std::array<boolean, 4> m_stepState{{true, true, true, true}};
std::array<boolean, 4> digitalReadValues;
std::array<int, 8> bit1{{0, 1, 0, 1, 0, 1, 0, 1}};
// int bit1[8] = {0, 1, 0, 1, 0, 1, 0, 1};
std::array<int, 8> bit2{{0, 0, 1, 1, 0, 0, 1, 1}};
std::array<int, 8> bit3{{0, 0, 0, 0, 1, 1, 1, 1}};
int16_t *wave1Values;
float defaultAttackValue = {50};
float defaultDecayValue = {200};
float defaultSustainValue = {200};
float defaultReleaseValue = {200};
float defaultVolume = {0.7};
unsigned long m_lastMillis;
static const int waveTotal = 4;
unsigned long m_stepStateInterval = 20;
unsigned int m_STEPNUM = 8;
unsigned int m_step = 0;
const int numReadings = 5; // Anzahl der Readings
int readings[5]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
float average = 0; // the average
int inputPin = A3; // Analog input
int average_bpm = 120;
int average_bpm_alt = 120;
unsigned long m_BPMInterval = 400;
int m_AnalogThreshold = 3;
int ADCFilterBefore;
float interval;
float minBPM = 40.0;
float maxBPM = 800.0;
long positionEnc1 = -999;
Encoder Enc1;
AudioSynthWaveform *waveform = new AudioSynthWaveform[4];
AudioEffectEnvelope *envelope = new AudioEffectEnvelope[4];
AudioMixer4 mixer1;
AudioOutputI2S i2s1;
AudioConnection patchCord1;
AudioConnection patchCord2;
AudioConnection patchCord3;
AudioConnection patchCord4;
AudioConnection patchCord5;
AudioConnection patchCord6;
AudioConnection patchCord7;
AudioConnection patchCord8;
AudioConnection patchCord9;
AudioConnection patchCord10;
AudioControlSGTL5000 sgtl5000_1;
int pin_Out_S0 = 2;
int pin_Out_S1 = 3;
int pin_Out_S2 = 4;
int buttonMuxState[8];
int potiMuxState[8];
int ledMuxCom = 14;
int buttonMuxCom = 15;
int potiMuxCom = 16;
int *pointerToAnalogValues;
private:
#endif
main.cpp:
#include <Arduino.h>
#include <SD.h>
#include <SerialFlash.h>
Display display;
Sequencer sequencer;
sequencer.muxInit();
display.init();
display.update();
sequencer.update(display.wave1Values);
