I found this LED series/parallel array wizard recently. According to it, I can power 70 LEDs with 9 volts. Is this legit?
If 9 volts can power 70 LEDs does this mean that an arduino board, powered by a nine volt battery, can power a series of 70 LEDs?
The wizard allows you to use the color of your LED to determine the diode forward current. Is this a safe bet? I have three packages of LEDS I purchased long ago-one red, one green and one yellow and I don't have the specs for them. The packages just say 3RD, 3GD and 3DY.
I don't think using the color to indicat the forward voltage is a very accurate way to do it.
Also running 70 LED's from a 9 volt battery, if it works at all it will not work for very long, 9v batteries don't hold much juice.
You can definitly not run 70 LED's directly from An Arduino board.
Any Arduino pin can source a absolute max of 40mA, but the voltage regulator on the board have an overall max of about 200mA without a heatsink. Even with a heatsink 70 LED's will draw too much current.
So i think an external powersupply of some kind is required.
Thanks MikMo,
Based on your post I have other questions.
These three packages of LEDs I have - I need to determine their forward voltage more accurately. Can you suggest a way to do this or an online resource that would help?
Is there an online resource that could help me determine how much power I need? There's likely a formula I should have memorized by now, right?
I've programmed the arduino to make the lights blink to a customized pattern. Because I want the arduino to turn the lights on and off on cue, I'm unclear about how to integrate an additional power source that likely will always be on/high. Any suggestions?
In the absence of a data sheet the only way to get the forward voltage is to measure it at a set current. This link shows you how to calculate resistor values and the thinking behind the formulas.
see:- http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
In all three schematics, I don't know how to read the thick black bar that is in between the resistor and the diode. Does it represent a component or is it just symbolic of part of the diode?
If you're talking about this: , then that symbol is for a Transistor.
That transistor will hold a couple hundred ma, so it depends on where your going to use it
Also it is PnP type, which (basically) means it will only turn on if the base (middle lead) is at 0 volts, kinda backwards
Finally if this is for the power supply, it is the wrong type, see the little arrow on the transistor schematic icon? if its pointing out that's a NpN type (if its pointing in its a PnP)
OK. Looks like I'll need to do more research on transistors. Thanks for the tips and head start.
Moving forward it's crucial that I determine the specs of the LEDs I have. Earlier in this thread i was told this:
"In the absence of a data sheet the only way to get the forward voltage is to measure it at a set current."
I'm unsure of how to do this. Do I use a multimeter? I'm hoping that someone out there could tell me how to measure the forward voltage of these LEDS. I bought them a few years ago - can't recall from where.
I'm pretty much guessing here, but this is what I would suppose:
Connect the + on power supply (after using appropriate resistors for safe use with the LED) to the + on the DMM (set on Ammeter mode). Then connect - of DMM to the + of the LED, and then the - of the LED to Ground (- of the battery).
Again, that could be completely wrong, but it's my guess :P. As long as you use appropriate resistors, I don't think there's any chance of hurting the LED.
There is a unlimited number of LED you can power with a 9vdc source. However they must be wired in parallel and each have it's own current limiting series resistor and of course the voltage source must have a current capacity equal to or greater the the combined load current of all the individual LEDs.
For series connected LEDs, you are limited to the sum of the number of the individual forward voltage drops of each LED, as to how many you could power from a 9vdc voltage source. For standard red LEDs I would think 6 or less would be the limit. You still need a current limiting resistor, but just one for the whole series string.
