LED stay on without using delay- Solved!
I still don't understand how to implement the knowledge from
BlinkWithoutDelay to a non-blinking simple replacement of
"delay(1000)" for an LED to stay on longer upon serial communication.
In this sketch, after putting in an "L" into the serial monitor
the LED comes on and doesn't turn off after a second.
Just stays on.
What can I do to replace the simple "delay(1000)"?
  Led staying on without delay
  Alexandra Klein
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
  // initialize serial communication:
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
{unsigned long TimerledPin;
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
                                  // if it's a capital H (ASCII 72), turn on the LED:
    if (incomingByte == 'H')
      {TimerledPin=millis(),
      digitalWrite(ledPin, HIGH);
      if (millis()-TimerledPin>= 1000UL)
      digitalWrite(ledPin,LOW);
You need to move the code to see if it is time to turn the LED off outside the conditional, so it is executed every time through "loop"
Thanks.
Which part?
This part of the code needs { } and moved out of the the "if" that it is inside of.
I would recommend moving your time variables out of the loop and using better names like what I am giving you.
unsigned long Oldtime = 0; // used to note the time the led was turned on
unsigned long Newtime = 0; //used to update to present time when = millis()
Thank you cyclegadget.
I think I know what you mean, and put the changes in the code,
but now, the LED doesn't come on at all when I press 'L'
into the serial monitor.
  Alexandra Klein
{if (millis()-TimerledPin>= 1000UL)
      digitalWrite(ledPin,LOW);}
You need to move the declaration of "TimerledPin" above "setup"
This is only my tryout code for the bigger project.
The serial really is an XBee communication trigger
between two Arduino LilyPads that are part of a
interactive jewellery project.
The code is:
  By Alexandra da Fonseca-Klein, Digital Jewellery project,
  For interactive Jewellery 'proximity sensing hearts'
  www.ADFK.co.uk; 2012
  2 Arduino Lilypad Simple Boards are connected via Xbee Series 2 radios.
  The Simple Board lacks Rx/Tx, therefore the use of SoftwareSerial.
  If the 2 wearers are within reach (30 feet approx) one LED
  comes on on the other wearers piece, if a button is pressed, another LED
  lights up. This is the receiver side.
#include <SoftwareSerial.h>        // use these specified set of commands
const int RXPin = 10;              // setting the pin to RX
const int TXPin = 11;              // setting the pin to TX
const int ButtonLed = 5;     // the number of the PushLed pin
const int ledPin =  13;      // the number of the LED pin
SoftwareSerial xbee (RXPin, TXPin);// defining the new serial name
void setup()                // definitions that are always true
  pinMode(ButtonLed, OUTPUT);
  xbee.begin(9600);// set the data rate for the SoftwareSerial port
void loop() // run over and over
  if
  (xbee.available()) // check if there is actually data coming from
  {                  // communication port
  digitalWrite(ledPin, HIGH);// set the LED on
  delay(500);               // wait for half a second
  else                      //if not
  digitalWrite(ledPin, LOW);// turn the LED off
  if
  (xbee.read() == 'L')     // if you read the letter 'L'
  digitalWrite(ButtonLed, HIGH);// set the ButtonLED on
  delay(1000);               // wait for a second
  digitalWrite(ButtonLed, LOW);// turn the ButtonLED off
    int incomingByte = Serial.read();
Thanks. It works.
I will now try the newly learned skill on the XBee project.
I implemented the avoid delay routine into my
project which essentially has 2 LEDs to run a few seconds.
One, if there is the letter "H" read from Serial (constantly)
and one, if there is a button pressed from the other board,
sending the letter 'L' out.
Now there are no problems with lighting the first LED without flicker,
but the second, ButtonLed only comes on once for about 5 seconds
after pressing the button, after that it only gives barely visible short
bursts of light when it is triggered.
Why is that?
const int RXPin = A4;              // setting the pin to RX
const int TXPin = A5;              // setting the pin to TX
unsigned long TimerButtonLed;
  if (millis()-TimerledPin>= 4000UL)
  if (xbee.available() > 0) {
    int incomingByte = xbee.read();
  if (millis()-ButtonLed>= 4000UL)
    // if it's a capital L, turn on the LED:
    if (incomingByte == 'L')
      TimerButtonLed=millis(),
Don't cross-post thanks, or there will be trouble.
A few things. You are reading the x-bee two times per loop when you only need to that once per loop. I removed one of the x-bee reads.
Second, your sketch was out of order in the way that you want it to work. Your order would probably still work but it makes it hard to find the problems. Try to write the sketch in steps in a way that you want things to happen. It should be: read serial...turn on correct LED....note the time...check the time and turn off LED after "X" millis.
Lastly, I think you had some of your comments placed in less than ideal locations. Also, use Auto format after every change in the sketch. Auto format makes it a bit easier to read. I also recommend a extra line between stages in the code. It makes it easier to follow the flow.
Thanks for the valuable tips.
I'll go at it right now.
And sorry for 'crossposting'.
I'm a bit on a tight schedule for the
college deadline...
Now that I had the more complex project
I thought it is better to repost it.
So I tried out the simplified version. This one doesn't work, though.
The LED13 doesn't come on, nor does the ButtonLed.
In the meantime I took my code that worked for
the LED13 and for one time only for the ButtonLed
and reverted back to using 'delay' for the ButtonLed and
leaving the better mills calculation on the top for the
LED13. Now at least it works good enough. There is
the odd time that the button has to be pressed again
because the program is busy, I think.
And of course that would mean we would give in a little,
because we would leave 'delay' in the backdoor again.
I would really like to do away with delay altogether.
Maybe you can spot, what is still wrong in the cleaned up
sketch that was posted by cyclegadget earlier. It looks good to me.
My 'botched' sketch, that works sort of, but with partly with 'delay' is here.
const int RXPin = A4 ;              // setting the pin to RX
  if
Your test for 'L' involves a read, but how do you know there's anything there to be read?
Do you mean in the last one that I posted or in the one from cyclegadget?
Your code
I'm sorry, I don't understand.
I check if XBee is available and it does read an 'L',
when I press the button,
otherwise the thing wouldn't be working.
What I don't understand is why the
new proposal from cyclegadget
doesn't work at all and my previous one
with both avoiding using delay only
works partly.
What are you suggesting?
I made a mistake and did not see you had incomingbyte defined as int. You are wanting an ascii character and those are variable char.
Put this in your defines area at the top of the sketch.
char incomingByte;
In the loop make your xbee.read section look like this:
    incomingByte = (char)xbee.read();
I had to write your sketch a little differently to test it on my Uno without the X-bee. I used lots of serial.prints to look for my mistake.
So that I could test the sketch I made it a little different and commented out the Xbee setup and used Serial.print and read.
Here is that code. It is not clean but, I didn't want to make a lot of changes and miss the original problem.
int ledState = LOW;
int ledState2 = LOW;
char incomingByte;    // a variable to read incoming serial data into
 // xbee.begin(9600);// set the data rate for the SoftwareSerial port
  unsigned long newtime = millis();
    incomingByte = (char)Serial.read();
    Serial.println(incomingByte);
    TimerledPin = millis(),
    ledState = HIGH;
    Serial.println("I got an H");
  if (newtime - TimerledPin >= 4000UL && ledState == HIGH)
    ledState = LOW;
    Serial.println("time is up for TimerledPin");
    TimerButtonLed = newtime;
    ledState2 = HIGH;
    Serial.println("I got a L");
  if (newtime - ButtonLed >= 4000UL && ledState2 == HIGH)
    ledState2 = LOW;
    Serial.println("time is up for ButtonLed");
