Led staying on after being pulled to a LOW state while using Millis()
A little background:
So I made a stand-alone Arduino using the atmega328-p QFN chip that incorporates NPN transistors in order to drive some LED's.
PCB layout:
I'm having an issue where when using the Millis() function, the LED stays dim after a digitalWrite LOW is sent to the output of the microcontroller.
The strange part is that when using "delay();", The LED turns completely off instead of staying slightly dim when using Millis().
LED's when using delay:
IMG_8404-ezgif.com-optimize
LED's when using millis()
ezgif.com-video-to-gif-converter (1)
Here is the code that is using Millis()
unsigned long BIAUXms = 0;
unsigned long currentms=0;
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
BIAUX();
currentms= millis();
void BIAUX(){
  if(currentms-BIAUXms>=50){
    digitalWrite(8,HIGH);
 if(currentms-BIAUXms>=100){
    digitalWrite(8,LOW);
  if(currentms-BIAUXms>=150){
 if(currentms-BIAUXms>=200){
  if(currentms-BIAUXms>=250){
 if(currentms-BIAUXms>=450){
  //Swtich Leds
  if(currentms-BIAUXms>=500){
    digitalWrite(7,HIGH);
 if(currentms-BIAUXms>=550){
    digitalWrite(7,LOW);
  if(currentms-BIAUXms>=600){
 if(currentms-BIAUXms>=650){
  if(currentms-BIAUXms>=700){
 if(currentms-BIAUXms>=900){
        BIAUXms=currentms;
Here is the code that is using delay()
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
delay(50);
delay(50);
delay(50);
delay(50);
delay(175);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(175);
delay(50);
Any help would be greatly appreciate!
Think about what the above snippet will do when currentms-BIAUXms is 899.
The LED will be turned on, then immediately back off. Followed by on/off/on/off/on/off... as fast as the processor can manage. So the LED will appear to stay on, though a little dimmer.
You need to rethink your code.
To add to my post, The 2 LED's are running of NPN 1 ( Digital Pin 7) and NPN 6 (Digital Pin 8). The LED that stays DIM after being set to LOW is digital Pin 7.
Thank you very much! I rewrote the code and it seems to work perfectly now!
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
BIAUX();
void BIAUX(){
    BIAUXms=currentms;
    else if(currentms-BIAUXms>=700){
    else if(currentms-BIAUXms>=650){
    else if(currentms-BIAUXms>=600){
    else if(currentms-BIAUXms>=550){
    //Swtich Leds
    else if(currentms-BIAUXms>=500){
    else if(currentms-BIAUXms>=450){
    else if(currentms-BIAUXms>=250){
    else if(currentms-BIAUXms>=200){
    else if(currentms-BIAUXms>=150){
    else if(currentms-BIAUXms>=100){
    else if(currentms-BIAUXms>=50){
