int a=0;
pinMode(A5,INPUT);
pinMode(13,OUTPUT);
a = digitalRead(A5);
if(a == 1)
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
i connect 5v pin to A5pin through pushbutton.
when i press the button the led is glowing.
but when i release the button, the led was turning off only after 5 second
Use a digital pin as input and use a pullup resistor for the button.
EDIT: Also not that pin 13 is used by the internal LED and that it is used as clock signal for SPI. Maybe another pin would be better.
He already is.
The suggestion to use a pullup resistor for the input is a good one and the easiest way to do it is to use
pinMode(A5, INPUT_PULLUP);
and to change the circuit so that the input is taken to GND (ie LOW) when the button is pressed
