Hello!
I recently bought a RGB LED strip and wanted to programm my arduino to use my bluetoothmodule, which reads the input, so i can swith between the different modes.
If I activate the fade mode, my Arduino is stuck in a loop and i have to reset it
Maybe you can help me to fix my problem. i already tried many things but nothing worked.
int ledred=8;
int ledgreen=9;
int ledblue=10;
int tx=1;
int rx=0;
int inSerInt = 0;
int mode = 0;
int reset = 7;
void setup(){
pinMode(ledred, OUTPUT);
pinMode(ledgreen, OUTPUT);
pinMode(ledblue, OUTPUT);
pinMode(reset, OUTPUT);
pinMode(tx, OUTPUT);
pinMode(rx, INPUT);
allpinslow();
Serial.println("Eingabe bitte!");
void loop(){
char inSerial[15];
int i=0;
int m=0;
if (Serial.available() > 0) {
while (Serial.available() > 0) {
inSerial[i]=Serial.read();
i++;
if(mode > 1)digitalWrite(reset, HIGH);
inSerial[i]='\0';
led(inSerial);
void allpinslow()
digitalWrite(ledred, LOW);
digitalWrite(ledgreen, LOW);
digitalWrite(ledblue, LOW);
void led(char inStr[]){
int i=0;
int m=0;
if(!strcmp(inStr,"red")){
mode++; //Ledred ON
allpinslow();
digitalWrite(ledred, HIGH);
Serial.println("Red ON");
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}
if(!strcmp(inStr,"green")){ //Ledgreen ON
mode++;
allpinslow();
digitalWrite(ledgreen, HIGH);
Serial.println("Green ON");
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}
if(!strcmp(inStr,"blue")){ //Ledblue ON
mode++;
allpinslow();
digitalWrite(ledblue, HIGH);
Serial.println("Blue ON");
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}
if(!strcmp(inStr,"fade")){
mode=1;
allpinslow();
Serial.println("Fade ON");
int r, g, b;
int FADESPEED;
FADESPEED = 5;
// fade from blue to violet
if(mode == 1){
for (r = 0; r < 256; r++) {
analogWrite(ledred, r);
delay(FADESPEED);
}else{Serial.println(r);}
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(ledblue, b);
delay(FADESPEED);
}else{Serial.println(b);}
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(ledgreen, g);
delay(FADESPEED);
}else{Serial.println(g);}
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
else{
for(m=0;m<11;m++){
inStr[m]=0;
i=0;
Thx
I used a bit of coding from GreatScott and an other website for the fade because I didn’t want to write that much
