LED Strip Flowing Pattern
I have 0 experience in any Arduino / IC / PIC / LED Programming. With that said, I am looking to build OR have built the following.
  • 4" LED addressable strip that runs in a Flow pattern from right to left, then starts back over at original the LED bulb and repeats. Likely only 4-5 LED bulbs, single color.
  • IC that is as small as possible. IE: No breadboard, No large Arduino board, Etc. Just an IC that can be mounted on the strip itself?
  • Needs to run on 6V (2 - 3V lithium ABC batteries) for at least 2 hours.
  • As bright as possible with timeframe requirements listed above.
Is this possible and if so, is it something a complete newb like myself could build?
Thanks for your time!
Mike
Is this possible
Yes perfect.
Another question altogether, but I suspect you could if you have a bit of experience first.
I would use an ATtiny85 chip. This is a small 8 pin chip that can be programmed with an Arduino and runs Arduino code.
The power requirement is the most tricky part. I would probably use a buck converter to get a 5V power supply as a conventional regulator would not run with a voltage so close to that which you want to produce on the output.
You will also need physical skills with a soldering iron and strip board construction.
They don't make single colour addressable strips, as far as I know. You could use addressable RGB strip and only use one colour. Or you could make your own strip from ordinary 3mm or 5mm LEDs on a 4" long stripboard. Not too difficult with only 5 LEDs.
In this "flowing" pattern, how many of the 5 LEDs are lit at any instant? What colour? Different colours have different "forward voltages" and can affect the design in certain ways: red LEDs have the lowest forward voltage and blue & white have the highest.
What are these ABC batteries? Google shows me large batteries for electric wheelchairs.
