LED Strip One color not working
I'm working on this project amblone Guide - Amblone Tech Blog
And basically I'm at the point where I'm done, only that for one strip, the red color is not working. I have troubleshooted and troubleshooted and cannot find the problem. I have a total of 3 led strips and the other 2 work perfectly. Here are the conditions
  1. When I touched ONLY the lead of the power supply to the positive commons of all the LEDs, the green LED lights faintly on the defective strip while the other two stay unlit. The negative from the power is NOT connected.
The wiring and soldering should not be an issue, is it a possible transistor issue? Because maybe one of the legs got heated for too long? Any advice regarding this would be helpful.
friendshipismagic:
Something is very wrong if you can have the negative side of the power supply unconnected and still get light.
Ok, new update, don't know why that was but that first condition is gone. Basically when everything is on, the red LED is off and I'm just going to resolder my joints again.
friendshipismagic:
[u]I'm working on this project amblone http://amblone.com/guide[/u]
1. When I touched ONLY the lead of the power supply to the positive commons of all the led lighting, the green LED lights faintly on the defective strip while the other two stay unlit. The negative from the power is NOT connected.
hello were you able to sort out the problem? I am facing similar issue with my lights..One color is not working.. Please help me to solve it.
