LED Strip, random pattern and color
So this is a two part question. I’m very new to coding and have been mostly copy pasting my functions with a very basic understanding of how they work.
Problem 1:
I would like to randomly select a pattern from a predefined list of patterns. I have been reading up on arrays but i’m not sure how to make it work for my functions.
Problem 2:
I would like each pattern to randomly select a color from a list of colors.
Essentially, I would want this to cycle through the random patterns with random predefined colors.
Here is the code without the actual pattern functions (Exceeds character limit)
#include “FastLED.h”
#define NUM_LEDS_A 37
#define NUM_LEDS 37
CRGB strip[NUM_LEDS_A];
#define PINA 6
#define BRIGHTNESS 30
FastLED.addLeds<NEOPIXEL, PINA>(strip, NUM_LEDS_A);
FastLED.setBrightness(BRIGHTNESS);
//list of function commands that cause a pattern
TwinkleRandom(500, 10, false);
Twinkle(255, 0, 0, 50, 50, false);
NewKITT(255, 0, 0, 2, 10, 50);
Strobe(255, 0, 0, 10, 50, 10);
FadeInOut(255, 0, 0);//red
CylonBounceLong(0, 0, 255, 4, 10, 100, 5); // blue
MeteorRain(255,255,0,2, 64, true, 10);//yellow
RunningLights(255,0,0,50); //RED
colorWipe(0,255,0, 10);
rainbowCycle(10);
theaterChase(255,0,0,50);
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Once you have set a pattern going how long do you want to run it for?
Would this be a fixed number of cycles of that pattern or for a fixed amount of time. The first is easy the second not so.
If it is the second then you have to convert all your pattern code into a state machine structure, this is a step up in difficulty than the normal code you are just getting to grips with. The essence of this is described here:- State Machine
If just a fixed number of cycles then just choose one of those functions at random using the "switch / case" structure. Look it up in the 'reference' entry in the Arduino's software help menu.
Then you have to change the code in each of those animations to do that. The list of colours will be in an array and you use a random number for the index of that array.
Cross-post. Thread locked.
