Hi, I have two LED-Strip, one is connected to an arduino MEGA and the other one is connected to an arduino UNO.
When I try to play both LED-Strip at the same time, something's not working, one of them starts blinking and the other doesn't do anything at all.
I already checked the connections between arduinos and the code for each arduino can be uploaded without any problems. What could it be?
Could it be a power issue?
I'm not sure about it, because I have a power source for each LED-Strip.
Right now, both of the LED-Strips are working, but it seems like the arduinos are not communicating with each other...
When I connect the first power source, which belongs to the first LED-Strip, the second LED-Strip starts blinking while doing its code
Why would they need to do that?
The thing is that one arduino has its LED-Strip turned down while the second one has to do a sequence. When the first arduino sends a message, it starts to do a sequence the first LED-Strip and the second one has to stop.
I have a question, ¿the power source for each arduino has to be 5V or 12V?
Welcome. You are not providing enough information or the right information to have any sensible reply to help you. Read the guide to getting the most out of this forum. It is the pinned post at the top of every section. Have a think and then provide information in one go rather than drip fed over many posts
That is not a good reason to use 2 Arduinos. Use 1 Arduino and the problem of communicating between Arduinos is gone.
Uno and Mega are 5V devices and need a 5V supply. They have built-in regulators which allow them to run from a higher voltage supply such as 12V, but these regulators cannot power 5V led strips.
For 5V led strips, get a 5V PSU with sufficient current for your strips. This PSU can supply the Arduino also through its 5V pin (which bypasses the built-in regulator).
For 12V strips, use a 12V PSU. This PSU can supply the Arduino though it's Vin pin, but take care not to draw more than a small current from the Arduino's 5V pin for other components.
