Can you give me the details of constant current led strip and constant voltage strip ?
Which is most suitable for the decorative lighting ? :o
Constant current and constant voltage are the two ways of controlling the current flow through an LED. When the LED power is large then you need constant current to ensure a safe stable power supply. If the current is low you can use constant voltage and have a current limiting resistor in line with the LED.
I am about as unsure of what you are actually asking as you are. What are you expecting a list of things you can buy? Is the decorative lighting to see directly, like Christmas tree lights or to illuminate a space? As this is an arduino forum what are you hoping to do with the arduino?
see these threads:- http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1234273497 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258412419
