LED strobe without delay for RC plane setup
Just looked at your rainbow code:
  for(j=0; j<256*10; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< NUM_LEDS; i++) {
      c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
      setPixel(i, *c, *(c+1), *(c+2));
    showStrip();
    delay(SpeedDelay);
If we strip out the chaff, we see:
  for(j=0; j<2560; j++)
    delay(SpeedDelay);
With SpeedDelay == 10mS, 2560 is 25.6-seconds.
You can't block like this and expect other stuff to run on time. ¯_(ツ)_/¯
You might try something like:
void rainbowCycle( void )
    byte
        i;
    static int
        cycle = 0;
    byte *c;
    static unsigned long
        timeRainbow == millis();
    if( (millis() - timeRainbow) < 10 )
        return;
    timeRainbow = millis();
        c = Wheel(((i * 256 / NUM_LEDS) + cycle) & 255);
    }//for
    cycle++;
    if( cycle == 2560 )
        cycle = 0;
    showStrip();
but that rainbow code is pretty computationally and bandwidth heavy. Would be interesting to see if there's enough cycles in one of these things to do it.
Sorry This is dragging on. Its not compiling now.
#include "FastLED.h"
#define NUM_LEDS 16
CRGB leds[NUM_LEDS];
#define PIN 4
#define NUM_LEDS_PER_STRIP 3
CRGB redLeds[NUM_LEDS_PER_STRIP];
CRGB greenLeds[NUM_LEDS_PER_STRIP];
#define STRB_STATE_A    0
#define STRB_STATE_B    1
#define STRB_STATE_C    2
#define STRB_STATE_D    3
#define WAIT_TIME       10  //mS
  FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.addLeds<NEOPIXEL, 2>(redLeds, NUM_LEDS_PER_STRIP);
  FastLED.addLeds<NEOPIXEL, 3>(greenLeds, NUM_LEDS_PER_STRIP);
//change
void Strobes( void )
    static int
        strobeState = STRB_STATE_A;
        strobeDelay = 0,
        strobeTimer = millis();
    unsigned long
        timeNow;
    timeNow = millis();
    if( (timeNow - strobeTimer) < strobeDelay )
        return;
    strobeTimer = timeNow;
    switch( strobeState )
        case    STRB_STATE_A:
            redLeds[0] = CRGB::White;
            redLeds[1] = CRGB::Red;
            redLeds[2] = CRGB::Red;
            greenLeds[0] = CRGB::White;
            greenLeds[1] = CRGB::Green;
            greenLeds[2] = CRGB::Green;
            strobeDelay = 100;   //100mS
            strobeState = STRB_STATE_B;
        case    STRB_STATE_B:
            // clear our current dot before we move on
            redLeds[0] = CRGB::Black;
            greenLeds[0] = CRGB::Black;
            strobeDelay = 50;   //50mS
            strobeState = STRB_STATE_C;
        case    STRB_STATE_C:
            strobeState = STRB_STATE_D;
        case    STRB_STATE_D:
            strobeDelay = 1000;   //1000mS
        default:
            strobeDelay = 0;
    }//switch
    FastLED.show();
}//Strobes
  Strobes();
  rainbowCycle();
    byte
        i;
    static int
        cycle = 0;
    byte *c;
        return;
    }//for
    cycle++;
    if( cycle == 2560 )
        cycle = 0;
    showStrip();
//Keep
void showStrip() {
 #ifdef ADAFRUIT_NEOPIXEL_H
   // NeoPixel
   strip.show();
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   FastLED.show();
 #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
I had a boo-boo in rainbowCycle():
Just remove one of the '=' signs there.
But it appears you've also removed Wheel but still try to call it:
    }//for
I guess I clipped the wheel portion off by mistake. Everything is working now. Still sitting at 105% of storage space (6370 bytes of available 6012). Ill play with the rainbowcycle and see if there is a way to clean things up a bit.
As always, thanks for the help.
#define NUM_LEDS 16
#define PIN 4
//change
    static int
        strobeDelay = 0,
    unsigned long
        timeNow;
    timeNow = millis();
        return;
        case    STRB_STATE_A:
        case    STRB_STATE_B:
        case    STRB_STATE_C:
        case    STRB_STATE_D:
        default:
            strobeDelay = 0;
    }//switch
    FastLED.show();
}//Strobes
  Strobes();
  rainbowCycle();
    byte
        i;
    static int
        cycle = 0;
    byte *c;
        return;
    }//for
    cycle++;
    if( cycle == 2560 )
        cycle = 0;
    showStrip();
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
}//wheel
//Keep
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
   // NeoPixel
 #endif
   // FastLED
 #endif
  showStrip();
Found a workaround in the mean time. You can load the micronucleus bootloader to the digispark and increase the memory from 6012 bytes to 6714 bytes.
Sweet fix. So it's all good now?
I think so. Thanks again for all of your help and pretty much fixing the sketch multiple times.
I really appreciate it.
Ian
