LED Switch with RF RCSwitch
Good evening everyone,
Excuse me if my English is not perfect, I am French.
I’m stuck on a problem with the RF 433MHz.
Let me explain,
I send a value by a remote control, this value will turn on or off a lamp. Except that if you do a continuous press, the lamp will blink, logical.
I bought the adapter a code I had made for the use of a pushbutton that works perfectly but could not use it with wireless.
The code is that as long as I support, I do not move on as a result of the program.
I use the RC-Switch library which I find very convenient.
Just have a simple handling, but I’ve been going round in circles for a while.
Here is the code for the pusher:
const int LED = 8;
const int PUSH = 12;
int compteur = 0;
void setup(){
  pinMode(LED, OUTPUT);
  pinMode(PUSH, INPUT);
  digitalWrite(LED, LOW);
void loop(){
  if (digitalRead(PUSH) == HIGH)   //Si value = 3283
    compteur = compteur + 1;
    while(digitalRead(PUSH) == HIGH);
    delay(50);
  if(compteur == 0)
  if(compteur == 1)
    digitalWrite(LED, HIGH);
  if(compteur == 2)
    compteur = 0;
And the one for the RF (The serial link serves me to see what happens):
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
const int LED = 8;
int value = 0;
boolean compteur = 0;
void setup(){
  mySwitch.enableReceive(0);
void loop(){
  if (mySwitch.getReceivedValue() == 3283)   //Si value = 3283
    compteur = compteur + 1;                //Compteur est incrémenté de +1
    mySwitch.resetAvailable();
    delay(50);
    while(mySwitch.getReceivedValue() == 3283);
    delay(50);
  if(compteur == 0)
    Serial.println("OFF");
  if(compteur == 1)
    Serial.println("ON");
  if(compteur == 2)
    compteur = 0;
For HF, I see hundreds of “on” and then after hundreds of “off” support, but the change is done all the time of the press, it is not blocked during the press.
I hope that I could explain myself as easily as possible and that you can help me.
I thank you in advance.
Good evening to you.
gg25
