Led to indicate connection between two modules
I've just finished building a track and field timing module that I've replicated from here. The project consists of two modules, a Start and Finish module. The finish module has two LEDS, one for power (which turns on when the module is powered on) and another one (not yet functional) to indicate that both modules have established a connection. However, it seems that the original creator of the project did not complete the code for this action to take place. Both modules use NRF24L01 which work with no issues.
I would like some help with creating some code for the Finish Module to check for a established connection with the Start Module when turned on and light up the second LED.
I've attached the code for both modules. Thank you
Start Module
#include <EEPROM.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
#include <Fonts/nunitoTiny.h>
#include <Fonts/makoSmall.h>
#define OLED_CLK   2
#define OLED_MOSI  3
#define OLED_RESET 4
#define OLED_DC    5
#define OLED_CS    6
Adafruit_SH1106 tft(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
RF24 radio(7, 8);
const byte addr[6] = "00001";
int up, down, select;
int pressed = -1;
int app = 0;
int mode = 0;
int menu = 0;
int m1 = 0; int m2 = 0; int s1 = 0; int s2 = 0; int s = 0;
int mm1 = 0; int mm2 = 0; int ss1 = 0; int ss2 = 0; int ss = 0;
boolean tme = false;
boolean done = false;
int times = 0;
int amt = 0;
unsigned long curr;
unsigned long prev;
int interval = 92;
int last;
// ----- BITMAPS ----- //
const unsigned char sprint[] PROGMEM = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x7f, 0xfe,
  0x00, 0x00,
  0x01, 0x40,
  0x02, 0xc0,
  0x00, 0x00,
  0x7f, 0xfe,
  0x00, 0x00,
  0x3c, 0x00,
  0x20, 0x00,
  0x00, 0x00,
  0x7f, 0xfe,
  0x00, 0x00,
  0x00, 0x00
const unsigned char lap[] PROGMEM = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x0f, 0xf0,
  0x3f, 0xfc,
  0x38, 0x1c,
  0x70, 0x0e,
  0x60, 0x06,
  0x60, 0x06,
  0x70, 0x0e,
  0x38, 0x1c,
  0x3f, 0xfc,
  0x0f, 0xf0,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
const unsigned char count[] PROGMEM = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x7f, 0xfe,
  0x6f, 0xb6,
  0x55, 0x2a,
  0x57, 0xba,
  0x55, 0xb6,
  0x6f, 0xa2,
  0x7f, 0xfe,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM settings[] = {
  0x00, 0x00,
  0x01, 0x80,
  0x01, 0x80,
  0x19, 0x98,
  0x1d, 0xb8,
  0x0f, 0xf0,
  0x07, 0xe0,
  0x7e, 0x7e,
  0x7e, 0x7e,
  0x07, 0xe0,
  0x0f, 0xf0,
  0x1d, 0xb8,
  0x19, 0x98,
  0x01, 0x80,
  0x01, 0x80,
  0x00, 0x00
static const unsigned char PROGMEM autos[] = {
  0x00, 0x00,
  0x03, 0xc0,
  0x01, 0x80,
  0x03, 0xc0,
  0x0d, 0x30,
  0x10, 0x28,
  0x10, 0x48,
  0x20, 0x44,
  0x21, 0x8c,
  0x31, 0x84,
  0x20, 0x04,
  0x10, 0x08,
  0x10, 0x08,
  0x0c, 0xb0,
  0x03, 0xc0,
  0x00, 0x00
static const unsigned char PROGMEM manual[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x03, 0xc0,
  0x0c, 0x30,
  0x10, 0x08,
  0x10, 0x08,
  0x26, 0x64,
  0x28, 0x94,
  0x2a, 0x94,
  0x26, 0x64,
  0x10, 0x08,
  0x10, 0x08,
  0x0c, 0x30,
  0x03, 0xc0,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM back[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x08, 0x00,
  0x18, 0x00,
  0x3f, 0xe0,
  0x3f, 0xf8,
  0x18, 0x38,
  0x08, 0x1c,
  0x00, 0x1c,
  0x00, 0x38,
  0x0f, 0xf8,
  0x0f, 0xe0,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM dist[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x7f, 0xfe,
  0x7f, 0xfe,
  0x6f, 0xbe,
  0x6d, 0xb6,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM sound[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x20,
  0x02, 0x10,
  0x06, 0x88,
  0x1e, 0x48,
  0x1e, 0x48,
  0x06, 0x88,
  0x02, 0x10,
  0x00, 0x20,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM nosound[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x80,
  0x01, 0x80,
  0x07, 0x80,
  0x07, 0x80,
  0x01, 0x80,
  0x00, 0x80,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
static const unsigned char PROGMEM racecal[] = {
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00,
  0x7f, 0xfe,
  0x00, 0x00,
  0x51, 0xc0,
  0x2a, 0x20,
  0x50, 0x40,
  0x28, 0x80,
  0x50, 0x00,
  0x28, 0x80,
  0x00, 0x00,
  0x7f, 0xfe,
  0x00, 0x00,
  0x00, 0x00,
  0x00, 0x00
  pinMode(14, INPUT);
  pinMode(15, INPUT);
  pinMode(16, INPUT);
  pinMode(9, INPUT);
  tft.begin(SH1106_SWITCHCAPVCC);
  radio.begin();
  radio.openReadingPipe(0, addr);
  radio.setPALevel(RF24_PA_MIN);
  radio.startListening();
  radio.flush_rx();
  tft.clearDisplay();
  tft.setTextColor(WHITE);
  int x, y;
  int16_t x1, y1;
  uint16_t w, h;
  tft.setFont(&nunitoTiny);
  tft.getTextBounds("Welcome", x, y, &x1, &y1, &w, &h);
  tft.setCursor(63 - (w / 2), 37);
  tft.print("Welcome");
  tft.display();
  int bar = 0;
  while(bar < 128) {
    tft.fillRect(0, 61, bar, 4, WHITE);
    bar = bar + random(1, 6);
    delay(random(4, 8));
    tft.display();
  tft.fillRect(0, 61, 128, 4, BLACK);
  tft.display();
  if(EEPROM.read(0) > 2) {
    EEPROM.write(0, 0);
  if(EEPROM.read(1) > 10) {
    EEPROM.write(1, 5);
  if(EEPROM.read(0) == 0) {
    tone(9, 440, 100);
    delay(100);
    tone(9, 659, 100);
    delay(100);
  noTone(9);
  delay(800);
  app = 0;
  menu = 0;
  drawApp(app);
  drawMenu(app, menu);
void drawApp(int appl) {
  tft.clearDisplay();
  if(appl == 0) {
    tme = false;
    tft.setFont(&makoSmall);
    tft.setCursor(46, 18);
    tft.print("Sprint");
    tft.setCursor(46, 29);
    tft.print("Lap");
    tft.setCursor(46, 40);
    tft.print("Counter");
    tft.setCursor(46, 51);
    tft.print("Settings");
  } else if(appl == 1) {
    tft.setCursor(46, 20);
    tft.print("Automatic");
    tft.setCursor(46, 36);
    tft.print("Manual");
    tft.setCursor(46, 52);
    tft.print("Back");
  } else if(appl == 2) {
    tft.setCursor(3, 8);
    tft.drawLine(3, 49, 123, 49, WHITE);
    tft.drawLine(88, 54, 91, 57, WHITE);
    tft.drawLine(91, 57, 88, 60, WHITE);
    tft.setCursor(100, 60);
    tft.print("Back");
    tft.setCursor(3, 28);
    m1 = 0; m2 = 0; s1 = 0; s2 = 0; s = 0;
    tft.print(String(m1) + String(m2) + ":" + String(s1) + String(s2) + "." + String(s));
    tft.display();
    tme = true;
    delay(100);
      tone(9, 523, 150);
      delay(random(1800, 3500));
      tone(9, 523, 150);
      delay(random(2300, 4100));
      tone(9, 1047, 300);
  } else if(appl == 3) {
    tft.setCursor(15, 60);
    tft.print("Start");
    tft.print("Back");
  } else if(appl == 4) {
    tft.print("Lap");
    tft.drawLine(74, 3, 74, 46, WHITE);
    tft.print("Back");
    tft.display();
    tme = true;
    times = 0;
    delay(100);
      tone(9, 523, 150);
      tone(9, 523, 150);
      tone(9, 1047, 300);
  } else if(appl == 5) {
    tft.print("Lap");
    tft.print("Back");
    tft.setCursor(3, 36);
    tft.print("Sel to Start");
    tft.display();
    tme = false;
    done = false;
    times = 0;
  } else if(appl == 6) {
    tft.print("Current");
    tft.setCursor(3, 40);
    tft.print("Last");
    int x, y;
    int16_t x1, y1;
    uint16_t w, h;
    tft.getTextBounds("Lane", x, y, &x1, &y1, &w, &h);
    tft.setCursor(124 - w, 8);
    tft.print("Lane");
    tft.getTextBounds("Num", x, y, &x1, &y1, &w, &h);
    tft.setCursor(124 - w, 40);
    tft.print("Num");
    tft.setCursor(3, 26);
    tft.setCursor(3, 58);
    tft.print("No Data");
    tft.setCursor(116, 26);
    tft.print(EEPROM.read(1));
    tft.getTextBounds("0", x, y, &x1, &y1, &w, &h);
    tft.setCursor(124 - w, 58);
    tft.print("0");
    tft.display();
    tme = false;
    done = false;
    amt = 0;
  } else if(appl == 8) {
    tme = false;
    tft.print("Distance");
    tft.print("Sound");
    tft.print("Lane Calib");
    tft.print("Back");
  } else if(appl == 9) {
    tme = false;
    tft.setCursor(7, 25);
    tft.print("Select Lane");
    tft.print("Back");
    tft.setCursor(7, 45);
  tft.display();
void drawMenu(int app, int item) {
  if(app == 0) {
    tft.fillRect(0, 0, 43, 64, BLACK);
    tft.drawLine(33, 0, 33, 63, WHITE);
    if(item == 0) {
      tft.drawLine(33, 12, 33, 18, BLACK);
      tft.drawLine(33, 11, 37, 15, WHITE);
      tft.drawLine(37, 15, 33, 19, WHITE);
      tft.drawBitmap(8, 24, sprint, 16, 16, WHITE);
    } else if(item == 1) {
      tft.drawLine(33, 23, 33, 29, BLACK);
      tft.drawLine(33, 22, 37, 26, WHITE);
      tft.drawLine(37, 26, 33, 30, WHITE);
      tft.drawBitmap(8, 24, lap, 16, 16, WHITE);
    } else if(item == 2) {
      tft.drawLine(33, 34, 33, 40, BLACK);
      tft.drawLine(33, 33, 37, 37, WHITE);
      tft.drawLine(37, 37, 33, 41, WHITE);
      tft.drawBitmap(8, 24, count, 16, 16, WHITE);
    } else if(item == 3) {
      tft.drawLine(33, 45, 33, 51, BLACK);
      tft.drawLine(33, 44, 37, 48, WHITE);
      tft.drawLine(37, 48, 33, 52, WHITE);
      tft.drawBitmap(8, 24, settings, 16, 16, WHITE);
  } else if(app == 1) {
    if(item == 0) {
      tft.drawLine(33, 13, 33, 19, BLACK);
      tft.drawLine(33, 12, 37, 16, WHITE);
      tft.drawLine(37, 16, 33, 20, WHITE);
      tft.drawBitmap(8, 24, autos, 16, 16, WHITE);
      tft.drawLine(33, 29, 33, 35, BLACK);
      tft.drawLine(33, 28, 37, 32, WHITE);
      tft.drawLine(37, 32, 33, 36, WHITE);
      tft.drawBitmap(8, 24, manual, 16, 16, WHITE);
      tft.drawBitmap(8, 24, back, 16, 16, WHITE);
  } else if(app == 3) {
    if(item == 0) {
      tft.fillRect(87, 53, 7, 10, BLACK);
      tft.drawLine(3, 54, 6, 57, WHITE);
      tft.drawLine(6, 57, 3, 60, WHITE);
      tft.fillRect(0, 53, 7, 10, BLACK);
  } else if(app == 5) {
    if(item == 0) {
  } else if(app == 7) {
    if(item == 0) {
  } else if(app == 8) {
    if(item == 0) {
      tft.drawBitmap(8, 24, dist, 16, 16, WHITE);
        tft.drawBitmap(8, 24, sound, 16, 16, WHITE);
        tft.drawBitmap(8, 24, nosound, 16, 16, WHITE);
      tft.drawBitmap(8, 24, racecal, 16, 16, WHITE);
  tft.display();
void events(int button) {
  if(app == 0) {
    if(button == 0) {
      if(menu != 0) {
        menu = menu - 1;
    } else if(button == 1) {
      if(menu != 3) {
        menu++;
    } else if(button == 2) {
      if(menu == 0) {
        app = 1;
        mode = 0;
        menu = 0;
        drawApp(app);
      } else if(menu == 1) {
        app = 1;
        mode = 1;
        menu = 0;
        drawApp(app);
      } else if(menu == 2) {
        app = 6;
        drawApp(app);
      } else if(menu == 3) {
        app = 8;
        menu = 0;
        drawApp(app);
    if(button == 0) {
      if(menu != 0) {
        menu = menu - 1;
      if(menu != 2) {
        menu++;
      if(menu == 0) {
        if(mode == 0) {
          app = 2;
          menu = 0;
          radio.flush_rx();
          drawApp(app);
        } else if(mode == 1) {
          app = 4;
          menu = 0;
          radio.flush_rx();
          drawApp(app);
        } else if(mode == 2) {
          app = 6;
          menu = 0;
          radio.flush_rx();
          drawApp(app);
        if(mode == 0) {
          app = 3;
          menu = 0;
          drawApp(app);
          app = 5;
          menu = 0;
          drawApp(app);
          app = 7;
          menu = 0;
          drawApp(app);
        app = 0;
        menu = 0;
        drawApp(app);
  } else if(app == 2) {
    if(button == 2) {
      app = 0;
      menu = 0;
      drawApp(app);
    if(button == 0) {
      if(menu == 0)
        menu = 1;
        menu = 0;
      if(menu == 0)
        menu = 1;
        menu = 0;
      if(menu == 0) {
        delay(100);
          tone(9, 1047, 300);
        tme = true;
        app = 0;
        menu = 0;
        drawApp(app);
  } else if(app == 4) {
    if(button == 2) {
      app = 0;
      menu = 0;
      drawApp(app);
    if(button == 0) {
      if(done == false) {
        app = 0;
        menu = 0;
        drawApp(app);
      if(done == false) {
        delay(100);
          tone(9, 523, 150);
          tone(9, 523, 150);
          tone(9, 1047, 300);
        tme = true;
        app = 0;
        menu = 0;
        drawApp(app);
  } else if(app == 6) {
    if(button == 2) {
      if(done == false) {
        delay(100);
          tone(9, 1047, 300);
        tme = true;
        done = true;
      } else if(done == true) {
        app = 0;
        menu = 0;
        drawApp(app);
    if(button == 0) {
      if(done == false) {
        app = 0;
        menu = 0;
        drawApp(app);
      if(done == false) {
        delay(100);
          tone(9, 523, 150);
          tone(9, 523, 150);
          tone(9, 1047, 300);
        tme = true;
        app = 0;
        menu = 0;
        drawApp(app);
    if(button == 0) {
      if(menu != 0) {
        menu = menu - 1;
      if(menu != 3) {
        menu++;
      if(menu == 0) {
        app = 9;
        drawApp(9);
          EEPROM.write(0, 1);
          tft.fillRect(8, 24, 16, 16, BLACK);
          EEPROM.write(0, 0);
        tft.display();
        app = 0;
        menu = 0;
        drawApp(app);
  } else if(app == 9) {
    if(button == 0) {
      if(EEPROM.read(1) != 8) {
        EEPROM.write(1, EEPROM.read(1) + 1);
        tft.fillRect(6, 32, 20, 20, BLACK);
        tft.display();
      if(EEPROM.read(1) != 1) {
        EEPROM.write(1, EEPROM.read(1) - 1);
        tft.display();
      app = 8;
      menu = 0;
      drawApp(app);
void getTime() {
  if(s == 9) {
    s = 0;
    s2++;
    if(s2 > 9) {
      s2 = 0;
      s1++;
      if(s1 > 5) {
        s1 = 0;
        m2++;
        if(m2 > 9) {
          m2 = 0;
          m1++;
          if(m1 > 9) {
            m1 = 0;
    s++;
boolean hasData() {
  if(radio.available()) {
    int distance;
    radio.read(&distance, sizeof(distance));
    if(distance < (EEPROM.read(1) * 100)) {
      return true;
  return false;
  up = digitalRead(16);
  down = digitalRead(15);
  select = digitalRead(14);
  if(up == HIGH && pressed == -1) {
    pressed = 0;
    events(0);
  } else if(down == HIGH && pressed == -1) {
    pressed = 1;
    events(1);
  } else if(select == HIGH && pressed == -1) {
    pressed = 2;
    events(2);
  if(up == LOW) {
    if(pressed == 0)
      pressed = -1;
  if(down == LOW) {
    if(pressed == 1)
      pressed = -1;
  if(select == LOW) {
    if(pressed == 2)
      pressed = -1;
  if(app == 2) {
    if(hasData()) {
      int text;
      radio.read(&text, sizeof(text));
      tme = false;
      curr = millis();
    if(curr - prev >= interval && tme == true) {
      prev = curr;
      getTime();
      delay(10);
    tft.fillRect(0, 16, 72, 13, BLACK);
    tft.display();
    if(hasData()) {
      int text;
      tme = false;
      if(tme == true)
        curr = millis();
      prev = curr;
      getTime();
      delay(10);
    tft.display();
    if(hasData() && last > 10) {
      int text;
      if(times < 4) {
        tft.setCursor(84, 12 + (times * 10));
        mm1 = m1; mm2 = m2; ss1 = s1; ss2 = s2; ss = s;
        times++;
        last = 0;
        curr = millis();
        if(times == 4) {
          tme = false;
    } else if(hasData()) {
      int text;
      curr = millis();
      curr = millis();
      prev = curr;
      getTime();
      last++;
    tft.display();
    if(hasData() && last >= 5) {
      int text;
      tft.fillRect(0, 46, 128, 13, BLACK);
      last = 0;
      curr = millis();
      amt++;
      int x, y;
      int16_t x1, y1;
      uint16_t w, h;
      tft.getTextBounds(String(amt), x, y, &x1, &y1, &w, &h);
      tft.print(String(amt));
      //Serial.println("Runner " + String(amt) + ": " + String(m1) + String(m2) + ":" + String(s1) + String(s2) + "." + String(s));
      int text;
      curr = millis();
      curr = millis();
      prev = curr;
      getTime();
      last++;
      delay(10);
    tft.fillRect(0, 14, 72, 13, BLACK);
    tft.display();
Finish Module
#include <DFRobot_TFmini.h>
#include <RF24.h>
SoftwareSerial mySerial(4, 5);
RF24 radio(7, 8);
DFRobot_TFmini TFmini;
uint16_t distance;
void setup(){
  TFmini.begin(mySerial);
  radio.begin();
  radio.openWritingPipe(addr);
  radio.stopListening();
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  digitalWrite(3, HIGH);
void loop(){
  if(TFmini.measure()){
    distance = TFmini.getDistance();
    if(distance < 20000 && distance > 0) {
      Serial.println(distance);
      radio.write(&distance, sizeof(distance));
You would need to send a heartbeat every second for example and if you don’t get the heartbeat for a couple second on the receiving end, then you turn the LED off
Why are you deleting comments? :thinking:
