I am a researcher who is trying to send both TTL pulses to another hardware while at the same time turning on an LED. What I want is this: no LED/TTL for 2000ms, LED/TTL on for 5000ms, then a loop of LED/TTL off for 500ms followed up LED/TTL on for 1000ms, and this loop continues indefinitely.
I get everything working the way I want for a few seconds, then the LED just turns on for a very long time and then stops and never turns on again... I am quite new to Arduino programming, and I have been trying to solve this for two days now. I really need to get this working for my research, so I hope you can help me.
Best,
Nils
/* DIGITALREAD - as fast as possible, check for changes and output them to the
* FTDI buffer using Serial.print() */
checkDigitalInputs();
/* STREAMREAD - processing incoming messagse as soon as possible, while still
* checking digital inputs. */
while (Firmata.available())
Firmata.processInput();
if (timer_state == -1) {
timer_new=millis();
if (timer_new>(timer_old+5000)) {
digitalWrite(LED, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(TTL, LOW);
timer_state = -2;
timer_old=millis();
else if (timer_state == -2) {
timer_new=millis();
digitalWrite(LED, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(TTL, HIGH);
timer_state = -3;
timer_old=millis();
else if (timer_state == -3) {
timer_new=millis();
timer_state = 0;
timer_old=millis();
else if (timer_state == 0) {
timer_new=millis();
if (timer_new>(timer_old+200)) {
timer_state = 1;
timer_old=millis();
randomtime = random(300, 800);
else if (timer_state == 1) {
timer_new=millis();
if (timer_new>(timer_old+randomtime)) {
timer_state = 0;
timer_old=millis();
